Fuselage Hangar
Fuselage Hangar
Hello all,
Been trying to figure out how I can store the fuse's of all my aircraft in order to keep em off the garage floor due to the never ending fear of one of em getting stepped on. It appears that I may or may NOT have found a good solution. I was in home depot last weekend and I stumbled upon this sort rail type rack system where the rail is screwed into wall studs and then the hooks actually clip on to this rail, I thought this was a really kool idea, but now I'm not so sure which leads to my question, is there anyone that hangs their aircraft being 15+ lbs on the wall by its tail?....too much weight on the stab?....
Thanks in advance
Biker
Thanks in advance
Biker
I do, but probably not that heavy. I have the clip rail system, but slightly modified. I built a "L" shaped shelf and then on the front facing, I added 3/4" dowels with pipe insulation to protect the planes finish. Give me to morrow to take a picture or two and I will post them. The thing I like about it is that the shelf can be moved up and down as necessary, and a couple of long brackets with the insulation can store the wings.
Here are the pics of my plane storage set up. I have also included one that I use for my parkflyers. The parkflyer rack looks crooked because it is. I just haven't glued it yet and the way it is built, I can always add more to the top if I want. Of course, eventually it will fall over... If you look underneath of the ultra stick lite in the 2nd picture, you can see where I bolted the shelf to the brackets. This keeps it from just sliding off and the brackets have holes in them already. And as you add different planes, you can move it up or down as needed. I had to do that when i put the Ultra Stick up.
VERY well done H!...I was thinking about something like that but with limited garage space (the kids ARE all outta the house finally) due to things still in the garage that shouldn't be, I decided to go this route with the "clip/rack" system...I was thinking about putting a hook near the nose of the heavier birds to take pressure off the tail, but not so much that the tail would disengage from its hook and fall...
