The Clubhouse If it doesn't fit in any other category and is about general RC stuff then post it here at the Clubhouse.
Why not run two RXs?
Reply
Old 11-30-2013, 07:20 AM
daveopam
My Feedback: (9)
daveopam's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Why not run two RXs?
Going to build a 30cc Ultimate. Futaba RXs have had a drastic price reduction of late. So instead of running pair of Y harness for the ailes. Why not run two RXs? I am thinking of useing a LifE battery pack that has two leads on it already. I understand that I will need an extra switch but is there another drawback I am not seeing? This seems like it would be an easy solution and I could even run one elev off of each RX and save a program mix.
Please give me any pro and cons that come to mind.
Thanks, David
daveopam is offline
Old 11-30-2013, 11:35 AM
perreback
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Pro: redundancy, which is always good.
Cons: can't think of any.
I'm not a Futaba man, so I don't know if you can bind two receivers to the same model memory in a Futaba tx, but I would imagine it's possible.
perreback is offline
Old 11-30-2013, 12:01 PM
daveopam
My Feedback: (9)
daveopam's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the reply. One the futaba 10C that I use the radio does not bind to a specific model. For example if I turn the TX on and it is on the wrong model it will control whatever model is turned on. Just like an old 72mhz did. So you do have to be carefull about making sure the TX is on the right plane.
David
daveopam is offline
Old 11-30-2013, 12:38 PM
JollyPopper
JollyPopper's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes, Futaba radios will do that. We have gone so far as to consider sitting a second airplane on the ground in front of a newbie and let him watch what the control surfaces are doing on the second plane while someone is flying the first plane. As long as both receivers are bound to a common transmitter, I see no reason that would not work.
JollyPopper is online now
Old 12-02-2013, 10:35 AM
ghostofpf1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Friend of mine ran 2 receivers in his glider to avoid drilling that large hole in the fuselage for wing wiring...one in the fuse for elevator and rudder and a micro in the wing for ailerons/flaps that he powered by using copper strips on the wing and wing saddle as power busses.Worked great
ghost
ghostofpf1 is offline
Old 12-02-2013, 11:40 AM
daveopam
My Feedback: (9)
daveopam's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Ghost.
daveopam is offline
Old 12-04-2013, 06:39 AM
BarracudaHockey
BarracudaHockey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
As an FYI, even if a transmitter binds to a specific model, that doesn't prevent two receivers being bound to the same transmitter or model memory.
BarracudaHockey is online now
Old 12-05-2013, 08:52 AM
dirtybird
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have six receivers bound to one TX. They are just in different AC
dirtybird is offline
Old 12-05-2013, 11:31 AM
init4fun
init4fun's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks, David
Hi David ,
I'm wondering what you ended up doing here , the 2 receivers or the Y harness ?
init4fun is offline
Old 12-05-2013, 01:35 PM
daveopam
My Feedback: (9)
daveopam's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The airframe is out of stock, but I am going to do two RXs. I just think it's a better set up and since the RXs are $40 each I don't see any down side.
David
daveopam is offline
Old 12-05-2013, 02:03 PM
init4fun
init4fun's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
David
The two receivers is the way I'd have gone too , and that's why I was wondering what you decided to go with . Hope it gets back IN stock for ya soon
init4fun is offline
Old 12-05-2013, 02:33 PM
daveopam
My Feedback: (9)
daveopam's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks. AW is supposed to give me an ETA this week.
daveopam is offline
Old 12-11-2013, 07:23 AM
daveopam
My Feedback: (9)
daveopam's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have had lots of time to think about this since the airframe will not be available till March.
I do see a potential problem. I had planned on running Hitec digital servos and still do. But now I see the need for a servo programmer if I use two RXs. I am picky about how I set up my stuff. And I want all the servo arms 90 degrees to the servo case so that throw is exactly the same through the range of motion on matched surfaces. There is no way to do this in the radio if I have one half of the elev plugged into the same channel of two separate RXs. I could still use a mix and use channel 2 on one RX and channel 5 on the other but that takes away the advantage of two RXs. Same story on the AILEs. While having them perfectly in synch is not as critical on the AILEs I still could not adjust end points and centering from the top to bottom wing.
The short of it is, I am not sure this is the best solution unless I buy a programmer. I have more time to think about it but wanted to post these concerns for others that followed this.
Later, David
daveopam is offline
Old 12-11-2013, 11:32 AM
AMA 74894
Moderator
AMA 74894's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
mmm you COULD use aluminum servo arms... the type with a cinch bolt through them so you can minutely adjust them (you can make adjustments much smaller than the teeth on the output arm...) I'm picky that way too!
of course for the cost of one set of servo arms you could probably just buy the programmer and be done with it
AMA 74894 is offline
Old 12-11-2013, 12:09 PM
init4fun
init4fun's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Post under construction
init4fun is offline
Old 12-11-2013, 12:10 PM
BarracudaHockey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nothing like over engineering a problem
Old 12-11-2013, 12:19 PM
init4fun
init4fun's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
But , , Isn't engineering it , , , , , supposed to be fun ?
I just figured , since a servo programmer was mentioned , I'd show the usual "weapon of choice" to give an idea of what he oughta be lookin for , in case he does go that route .
PS , God bless Engineers , they have given us Mechanics some REALLY good laughs over the years
init4fun is offline
Old 12-11-2013, 03:01 PM
init4fun
init4fun's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Oh , and , forgot to add , I'm sorry to hear it won't be available till march ....
init4fun is offline
Old 12-11-2013, 03:37 PM
daveopam
My Feedback: (9)
daveopam's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Not a bad idea Jim. But as you said the programmer would be less money and I have several other planes I could use it on. Of course the Y harness on the ailerons would still have the same set of issues but a simple mix would cure the elev issue.
daveopam is offline
Old 12-13-2013, 06:26 PM
TexasAirBoss
My Feedback: (22)
TexasAirBoss's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Its better to have two separate batteries. Then one entire system can fail and the other will continue to work. Typically, with mixed surfaces, like elevator halves and ailerons, place one on each receiver. Then if one side fails, you still have the other half. A friend was letting someone fly his giant SBach 342 . The pilot said something feels weird. He landed and we learned that one receiver/battery had died. It sold me.
TexasAirBoss is offline
Old 12-13-2013, 08:32 PM
daveopam
My Feedback: (9)
daveopam's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you TAB. I agree with you that two batteries is more redundant. But for my situation on a30cc plane I just can't see it. If I go the one RX route I won't be running two batteries. So I will probably stick with one pack either way. But I do thank you for your input
thanks again, David
daveopam is offline
Contact Us Archive Advertising Cookie Policy
