The Clubhouse If it doesn't fit in any other category and is about general RC stuff then post it here at the Clubhouse.
Coverite 21st Century Fabric covering
Old 06-03-2016, 06:01 PM
Hiyyosil
My Feedback: (22)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Coverite 21st Century Fabric covering
What is the real story on using this covering?? I been told it doesn't stick well, the glue is 'thin' and pulls apart on the edges,
it doesn't work well around curves, etc.
I'm trying to decide with what to cover my new Super Cub and I thought 21st Century Fabric was the answer...maybe not.
Any input would be appreciated....
Hiyyosil is offline
Old 06-04-2016, 05:45 PM
STUKA BARRY
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It sticks to itself just fine. Compound curves are tricky, but nothing on a Cub is tricky. You will be happy with it, and its very strong. You will need a sharp exacto to cut it. Its a little cheaper than Solartex and has that fabric look. You will like it.
STUKA BARRY is offline
Old 06-05-2016, 05:23 AM
TomCrump
TomCrump's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
21st Century Fabric used to be my favorite fabric covering. It shrinks so well that it does tend to pull from the edges. If you leave plenty of overlap, you'll be fine.
If you are concerned about adhesion, an application of Balsarite will alleviate your fears.
These days, I've switched to Solartex. It is easier to apply, but the colored varieties should be clear coated to make the covering easier to clean.
TomCrump is offline
Old 06-12-2016, 07:36 PM
countilaw
countilaw's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The best thing about it is the look of silk and dope finish.
Frank
countilaw is offline
Old 06-18-2016, 04:06 PM
DavidAgar
My Feedback: (107)
DavidAgar's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I switched to Solartex and never looked back. It goes on easy, does not sag and I have painted it with Latex paints. May cost a little more, but so worth it. Good Luck, Dave
DavidAgar is offline
Old 06-19-2016, 04:21 AM
Rodney
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Same as Dave, now use Solartex or Ceconite anytime I need a fabric covering. Solartex is so much easier to apply than Coverite, especially on compound surfaces. If you do not mind the extra work of sealing and painting, Ceconite is the most realistic (it is the real thing used on many planes) of all.
Rodney is offline
Old 06-20-2016, 12:27 PM
FLAPSDOWN
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Rodney, that's the real differentiator in my opinion. If you do not want to seal or paint your model after covering, use Coverite. I use it on sport models where I'd like a fabric-like finish. I use Solartex on my scale models that have fabric covered rubber, elevators and ailerons.
For the best finish on a fully fabric covered scale model, I use Sig Koverall and dope.
To each his own.
Bill
FLAPSDOWN is offline
Old 06-20-2016, 01:56 PM
TomCrump
TomCrump's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
[QUOTE=FLAPSDOWN;12226277
For the best finish on a fully fabric covered scale model, I use Sig Coverall and dope.
Bill[/QUOTE]
Why and how is Koverall the best ?
TomCrump is offline
Old 06-20-2016, 03:26 PM
FLAPSDOWN
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
TomCrump, Koverall has the most scale like finish when sealed and painted with Nitrate dope, again, in my opinion. I'd use silk but it simply isn't as easy to apply as Koverall. I use Solartex on giant scale fabric covered rudder, elevators and ailerons and paint them with Klass Kote after priming.
Old 06-21-2016, 03:26 AM
TomCrump
TomCrump's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Solartex is much easier to apply, and doesn't require the weave to be filled. It requires no primer, and once painted, you can't tell the difference between it and Koverall.. That's why many prefer it.
TomCrump is offline
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
