help with tactic 850
Does anyone have a step by step instruction isetting up a tactic tt850 and 825 receiver in a receiver ready sensei plane.The flyzone instructions address the 650 ,and I have most functions esc brake is on and throttle is back wards.I'm sure it is some small thing I overlooked
Thank S.T.C.
Thank S.T.C.
MN
Thank S.T.C.
Thank S.T.C.
Thanks Guys yes I did reverse the channel that the throttle is hooked up to,Cannel 3 Then the stick operates as it should but the brake is still on ,followed the instructions for turning the brake off,to no avail.Everything else seems to be ok ,do you think I can safely fly the Sensei ?As I see it the prop just doesn't coast to a stop.Anxious to lift off my very first flight w/fixed wing.Thanks again S.T.C.
