Cutting foam cores with a car battery
I watched a youtube vid on cutting foam cores with the cutting wire attached to a 12v car battery, and nothing more. The vid did not go into any detail of the set up. Anyone know what gauge of wire and width of wire would be correct to make this work?
I tried that once, did not like it as I had no easy way to adjust the temp of the wire. I used the door bell transformer and dimmer switch with good results. Easy enough to do and cheap. I have thought about using an old ESC, servo driver and lipo battery to power the foam cutter.
I got a good deal on a rheostat. Way more power than I really need. But for $12.00 was hard to not pass up.
My standard setup is some old control line cable 0.045 I think. My bow is 42 inches wide, plus I have a jig saw band saw cutter too with 18 inches of the same wire. The door bell works very well with the 18 inches, a little under powered on the bow.
Buzz.
Buzz.
