looking to buy Ceramic ball bearings
Hi guys,
am new here so pls bear with me.
what bearings would you suggest for using in a mini jet.
what do you guys think of ceramic ball bearings & where can i get them.
you have any experience with them, anything tat I should know before taking the plunge...
am looking to use in a mini jet turbine
Thank you bro, I was searching so long to find one...
I'm happy to have helped you . I personally have never used a ceramic bearing because as was said earlier they don't hold up well to the pounding loads a reciprocating engine puts on them , but I have done business with Boca Bearings more times than I can count (all of my glow engines have Boca stainless steel bearings in them) and the company has done right by me every time . The best thing about them is that you don't need to know the size or pedigree of your bearings if your talking glow engines , you can just call them up and say "I need bearings for an OS 90 four stroke" for example and they know the right bearings to fit . In fact , if your turbine is a commercially manufactured unit like a "Jetcat" or "Wren" for example , they may well have the specs for those like they do for the glow engines . Since your doing a turbine that has no reciprocating motion the ceramics should be an excellent choice , just as long as they are rated for the heat they will encounter in the turbine environment .
I wish you the best of luck with your project and remember , pictures are always welcome .
PS , this is my Saito 270 (45 cc) four stroke twin , having it's first test run after I installed a set of Boca Bearings in it .....
Maybe he already did and got the typical company line of "use our $100 special bearings or else" that most manufacturers will parrot to such questions , and then came here asking folks who may actually have some real advice to offer .
