The Clubhouse If it doesn't fit in any other category and is about general RC stuff then post it here at the Clubhouse.
Crash Engine Salvage
Reply
Old 11-22-2017, 07:52 PM
longbaot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Crash Engine Salvage
My OS FS91 with pump was in a crashed 4 months ago. Today I recovered the plane. I need to know how to salvage the engine after 4 months of exposure to the elements. It appears the exhaust opening was facing down and it is my hope that rain water did not enter. Also the carb opening was not facing up. I am able to turn the crank easily for 1/8 turn before it feels like it is hitting something. Help!
longbaot is offline
Old 11-23-2017, 07:26 AM
wnewbury
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Take it apart before trying to turn it over? Turning it over could damage it more if it got dirt inside. Parts are so expensive that I'd be tempted to buy another engine and use this one for parts. Good Luck.
wnewbury is offline
Old 11-23-2017, 09:13 AM
Twinhydro
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
As mentioned take it completely apart and clean with mineral spirits or similar to start with and blow off with compressed air . Plan on replacing the bearings for sure and clean any rust of crank etc with some bronze wool from the hardware store . Clean piston and sleeve further in hot soapy water , blow dry and lubricate . Bearings are readily available from Boca Bearing in FL . If you need help send a message and I'll see if I can walk you through it . Not many parts in one of these engines so not too bad to deal with .
Twinhydro is offline
