Go Back  RCU Forums > Radios, Batteries, Clubhouse and more > The Clubhouse
Reload this Page >
Spray on ingredients to seal monokote trim over monokote...
The Clubhouse If it doesn't fit in any other category and is about general RC stuff then post it here at the Clubhouse.
Reply
Old 02-18-2019, 03:54 PM
sdkeeney@windstream.net
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Spray on ingredients to seal monokote trim over monokote...
I'm trying to relocate a complete set of pics covering Tom Herrs 55/60 ArrowMaster in monokote...I've lost the web-site for this complete start tonfinish series...In it, they discussed a solution of TrimCoat, ammonia, water, and liquid detergent to use when applying monokote trim on top of monokote...I was hoping to find someinevwho might be familiar with the web-site, or better yet, the ingredients to the solution..
thanks,
N5225SDK
sdkeeney@windstream.net is offline
Old 02-18-2019, 11:42 PM
egldriver
egldriver's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've got a bottle of TF trim solvent if that helps and some trim sheets
egldriver is offline
Old 02-18-2019, 11:44 PM
egldriver
egldriver's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Old 02-19-2019, 11:39 AM
TomCrump
TomCrump's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Research the "Windex Method" for applying trim. You should find what you require.
TomCrump is offline
Old 02-19-2019, 02:46 PM
egldriver
egldriver's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
windex worked well when i applied stars and bars etc to monokote
Old 02-23-2019, 11:45 PM
DGrant
DGrant's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
When I'm doing TrimKote, I just take a bowl of appropriate size for the graphics I'm applying. I put a few drops of dishwashing liquid in it(maybe 3 or 4 if it's a large bowl), put water in, and stir it.
I take my graphic and dip it through the bowl making sure I get the whole thing wet, then I carefully place it as close as I can, and holding onto a corner I can get it perfect, as the water solution will let it slide and shift if needed. One I have it placed perfectly where I want it, I just use a soft cloth and blot/press it carefully so it won't shift, and to work any bubbles out(there's usually nothing though).
After it's all blotted, and it sits overnight, that stuff is stuck stuck. Seriously there's no special solution.... This or any of the above techniques others mentioned will work just fine. It works for many adhesive applications actually.
The adhesive on TrimKote isn't water soluble, and water doesn't affect it at all, other then creating a barrier so the adhesive can't stick to the film. The soap only is a lubricant. Once the water/soap evaporates the TrimKote is nearly vacuum sealed in a sense.
DGrant is offline
