The Clubhouse If it doesn't fit in any other category and is about general RC stuff then post it here at the Clubhouse.
How Much Engine- 1/4 Dr1 Triplane
Reply
Old 02-24-2003, 07:32 AM
G.F. Reid
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default How Much Engine- 1/4 Dr1 Triplane
I haven't had direct experience with it but I've been following quite a few threads on the BUSA quarter scale WWI planes as I'm interested in having one some day. From what I've seen in these threads, the G-23 is a good match. BUSA also recommends it.
G.F. Reid is offline
Old 02-24-2003, 07:24 PM
daveopam
My Feedback: (9)
daveopam's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Several years ago I saw a 1/4 Dr 1 at our fly in. I dont know what kit it was , but it was OS1.20 powered.
it flew it ok but those three wings make for plenty of drag. I would put the Saito 1.80 on it. A glow 1.80 will make
a lot more power than a gas1.80. The gas will be cheaper to run, but power to weight ratio will be better with
glow. later daveo
daveopam is offline
Old 02-25-2003, 02:34 AM
FHHuber
Banned
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Depends on how heavy the plane comes out when you're done...
At 10 lbs, a .91(4-stroke on all engine sizes) would fly it OK, a 1.20 would let you torque-roll it. At 13 to 15 lbs, you'd need the 1.20 to fly... and most current modelers would want the 1.80. If you hit 20 lbs.. you won't be happy with the plane no matter what engine you stick on it, because you'll be in the range where the engine torque (of the required engine) will make the plane nearly uncontrollable on the ground.
The Dr1 is a tricky critter on the ground... make your scale wing skids functional, you'll use them. If you have ANY problems with torque-turning when handling any other taildragger... you aren't ready for a Dr1.
FHHuber is offline
