40 size GP clipped wing Cub ailerons
VA
Hi have a 40 sized Great Planes Chipped wing cub bought at auction.
wing span 64", ailerons 12" and FLAPS 9"
Question: Will the 12" airleron work safetly? Should I rework the flats, converting them
back into aileron sections and join them to the existing ailerons.
My Feedback: (9)
It will work fine. You can always increase the throw if they are not quick enough for you. It depends I guess in what kind of flying you do. For scale you should have plenty. A cub seems to turn better with a little rudder.
Try mixing some in if you arn't happy with the AILE performance. later daveo
