extreme cold effects on equipment
MS
Would extreme cold (10 F) be detrimental to my transmitter for a period of about 48 hrs?
I am presently moving. All of my stuff is in a Moving truck parked in my front yard. My wife was fretting over some of her stuff in the truck, so it brought the question to mind.
ND
RE: extreme cold effects on equipment
haha, extreme cold... it is currently -40 outside, take your pick, celcius or ferenheit, doesn't matter to me... [8D]
anyway, it should be ok at 10f for that time, the screen might be a little sluggish if you power it up, but no damage.
My Feedback: (18)
GA
No, not unless you have water in or on it. Don't panic if when you turn the Tx on the screen is a kaleidescope of colors , it'll come back to normal after a while.
It's -24 here, and I can tell you that it sure has had an effect on MY equipment!
Don't worry about it. In some cases it CAN be harmful, but there's no sense worrying about it till you get it out of there. Chances are everything will be just fine.
However, rapid temp changes can have a worst effect than the extreme cold. When you get to it, wrap it in a towel, bring it indoors, and let it sit for 24 - 48 hours so it will warm up slowly.
My Feedback: (16)
GA
Most non-automotive/military equipment has a storage temp down to 0 degrees F. You should not have any problems. I would not power up the unit out of storage. I would let it warm up before using it. Thermal shock needs to be avoided.
My Feedback: (26)
WI
Na, I flew last Saturday for several hours in that same temp with a JR computer radio. If it can function in those temps, it sure can be stored in them.
MT
I left my plane and radio outside in an un-heated shed for the last week in temps. that ranged from +9 deg. F to well below 0. I charged the batteries last nite, in the same un-heated shed and flew my plane today for an hour and a half in 40+ deg. weather with no ill effects. I fly next my home so there was no rapid temp. changes (other than 9 deg. to 42 deg. within 24 hrs., typical Montana weather!) I would'nt worry about it.
It's your thumbs you need to keep warm. Actually, I have all my equipment in the garage and it sits through the cold and hot. I haven't had any problems. I think the slow warm up is a good idea as well. I have heard it is hard on batteries, but I keep mine on trickle with a Digi-pulse charger, and once a month recycle even if I haven't flown. I have more problems with adjusting the engines more than anything else.
