The Clubhouse If it doesn't fit in any other category and is about general RC stuff then post it here at the Clubhouse.
i need HELP with a speed control
Reply
Old 03-27-2003, 04:54 AM
proman_11
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default i need HELP with a speed control
hi i have blown two speed 5amp controls i went to the hobby shop and they fitted one in for me. it worked fine for a few mins then i change the batt and then it didnt work. my servos move right by i cant start the motor. please help my mum qont let me buy a new plane
proman_11 is offline
Old 03-27-2003, 09:41 AM
00hex
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What did you change about the battery? If you went to a higher voltage maybe the motor drew more than 5 amps and burned it out.
00hex is offline
Old 03-27-2003, 08:13 PM
Tippie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Why don't you let the hobby shop trouble shoot the problem for you. They are the ones that sold the ESC
to you. Maybe it's the wrong size ESC for the motor, maybe it's the way you have it hooked up. Since they
(the hobby shop) can visually see what you have get them to fix it.
Tippie is offline
Old 03-28-2003, 03:00 AM
proman_11
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i used the exact same batt. how can it burn out and the servos still work?
Old 03-28-2003, 09:52 AM
Bill L
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
PROTECT YOUR ESC: The esc's cost 10 to 100 times as much as a mini auto fuse. I put mini fuses in series with one motor connection, and they add less than 1 gram of weight. I learned at the cost of a $50 esc[img]i/expressions/face-icon-small-sad.gif[/img] and the hobby shop owner never mentioned it.[img]i/expressions/face-icon-small-tongue.gif[/img]
Bill L is offline
Old 03-28-2003, 10:40 AM
Tippie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The servos still work because they are not a function of the ESC. The ESC (Electronic Speed Control) deals with motor, thats it. The ESC is plugged into the receiver not the receiver plugged into the ESC. The servos will continue to work as long as you don't blow up the battery. You have a motor problem, be it wiring, wrong size ESC, or some other problem. You don't say what kind of motor you have, new? used? damaged?. Don't get another ESC until you figure out what went wrong with the previous 2 ESC's.
Tippie is offline
Old 03-28-2003, 11:24 PM
FHHuber
Banned
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
There's 2 separate circuits in the ESC. The circuit for motor control and the circuit for the BEC system. Its easy to blow the ESC section without blowing the BEC section (which is just a voltage regulator)
FHHuber is offline
Old 03-29-2003, 12:07 AM
proman_11
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks so do ya rekon i should buy my 4th speed control! my last two burnt but this one did nothing no smoke of any thing.a real dissapointment
Old 03-29-2003, 01:46 AM
FHHuber
Banned
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You need to find out WHY you are burning the speed controls out...
one... might be factory defect. two...you need to be looking for something wrong with the motor. three and you're just wasting money.
FHHuber is offline
Old 03-29-2003, 11:54 AM
Bill L
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Before you go any further, PUT A FUSE IN SERIES WITH THE MOTOR![img]i/expressions/face-icon-small-mad.gif[/img] Then try running the motor, directly from the batteries. Does it RUN?[img]i/expressions/face-icon-small-confused.gif[/img] Like the others said, Your servos will work fine, even with a busted ESC.
Are you real sure all the wires are correctly connected. Screw up the battery connections, and PUFF[img]i/expressions/face-icon-small-shocked.gif[/img] There goes the EXC.
Bill L is offline
Old 04-02-2003, 05:13 AM
proman_11
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
wooh you guys must be smart if im right
i connected 2 aa batts to the motor direct it didnt buge bu the speed control was still connected will that effect
i also tried a differnt motor and it worked. so do you think its a burnt motor?
wow my plane is bad luck
