NEED HELP AND INFO FOR A McCOY .19
THE INFO I NEED FOR THIS ENGINE IS I NEED TO KNOW ARE THEY GOOD ENGINES AND I KNOW IT IS AN OLD ENGINE BUT WHAT ALL CAN YOU PUT ON THIS OLD ENGINE Mc COY .19
SC
I'm afraid I'm not going to be able to help you much. I got this motor on a car back in 1977. As I recall it had no muffler on it the few times I ran it. The car had a two speed gear box and was uncontrollable in either gear and no matter what speed the motor was at....just spun the tires. Hopefully some others here will have had more experience with them.
Jeff
Jeff
First, you didn't say if this was the RC version.
Does it have good compression ?
What do you want to put it on ?
By todays engines, no it is not that fast.
The old 19 will be flown on vintage class RC or FF.
It would be a waste of your time and money if the rings are shot
or the bushings are worn. Does it look new or very used ?
If you have a 48" Comet Clipper or 2 1/2 meter glider then that
would be a good motor for them.
Tower Hobbies sells Tatone universal mufflers for the 19/29.
Randy
Randy
IT IS NEW THE INSIDE IS ALL CLEAN AND DRY NOT A DROP OF FUEL RUN THROUGH IT I WANTED TO USE IT ON A SCRATCH BUILT PLANE I SAW FROM SPADTOTHEBONE.COM
