need the construction article for...
Hi every one!
I have a small request.
Can someone scan me the construction article of the”RV-6F“? It was publish at April 97 on RCM.
I need it because I want to build the RV as a second plane and I couldn’t find any information on it.
Thanks!!
Hagay
[email protected]
Thanks!!
Hagay
[email protected]
PA
RE: need the construction article for...
You can order a photocopy from the AMA Library at www.modelaircraft.org/ You do not have to be a member to do this.
Hi Hagay;
Greetings to you from the 'Valley of the SUn'.
I have the April, 97 issue of RCM that I would be willing to part with. I do not know what the mailing costs would be to the Netherlands. The magazine itself is in good condition, and complete, however to save costs I could cut the article out for you. Let me know if you are interested. Best regards to you from cloudy and almost warm, Phoenix, Arizona, USA.
Joe Nagy. emai: [email protected]
