The Clubhouse If it doesn't fit in any other category and is about general RC stuff then post it here at the Clubhouse.
Foam Cutting ?
Reply
Old 06-20-2002, 10:42 AM
Slowbatics
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Foam Cutting ?
COULD SOMEONE ADVISE ME AS TO WHAT TO USE AS A POWER SOURCE FOR A HOT WIRE?
THANKS
Slowbatics is offline
Old 06-20-2002, 11:33 AM
gsoav8r
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 12v
I think most people use a 12v source and adjust the temp of the wire by adjusting the distance between the clips on the leads.
Ive found that if im using a short bow, 24 inches or less, I can use the 12v 7 amp battery from my field box. If I use a longer bow I need to use a battery with more amps, like a car batt.
I think www.usrcjc.org has a diagram showing this method and also how to make a transformer for using household current 110~120.
Cheers.
James
gsoav8r is offline
