Head gaskets
WI
Head gaskets
Can Masking Tape be used as head gasket material? Engine in question is a K&B 40 areo. I'm going through glow plugs (Hanger9 sport plugs) like mad and was going to attempt to reduce compression a bit by using a head gasket. I've been using Sig 10% nitro and first will try 5%. If that doesn't work I'll have to go with a head gasket.
AZ
Head gaskets
NO MASKING TAPE!!! Go to your nearest auto supply store and buy some brass shim stock. You can make a head gasket with a little patience. To punch the holes for the head bolts to pass through use a regular leather punch. The rest of the cutting can probably be done with an Xacto knife.
RI
Head gaskets
You're probably running it too lean., but if you want to reduce compression, go from a RC long to an RC short glow plug. You can also double up on the glow plug gasket.
WI
Head gaskets
Thanks for the replies. Where can you buy Fox idle bar plugs anymore. I always used them in the past but can no longer get them. I was told that they're not made anymore and have noticed that few companies are offering an idle bar plug. In fact, I've not found any in a long plug. I'll avoid the tape. As far as running lean, I believe this to be the problem also but I'm having a problem with midrange when I richen it. I blame most of my adjustment problem on the needle valve. Seems I always have problems with adjustment when the needle valve is independent from the carb. They might be safer, but I hate 'em and will never buy another engine that has them. Thanks again to all.
AZ
Head gaskets
The last idle bar plugs I got were from RJL. They sell K&B, Mecoa, and HP engines to name a few. They are listed in the classified section of most model magazines. They are listed in the August issue of Model Airplane News on page 97 under Mecoa. Website is www.mecoa.com. They list both long and short reach idle bar plugs at $3.90 or a card of 12 for $35.10.
Head gaskets
K&B sold a set of different thicknesses head gaskets for the 40. Check with Frank Bowman at [email protected]. He has a bunch of K&B parts, and also makes rings and gaskets.
Jim
Jim
