Lubrication of air systems?
My Feedback: (80)
MI
Does anyone use a lubricant in their air system? I have heard that some use a fine oil to lube the O rings in the cylinders. If so, then where may I get some. I am looking to seal some slow leaks. Thanks!
Lubricant for air systems
I too had this problem. Called Robart and they told me to coat the O rings with white lithium grease. available at auto parts stores. hopes this helps. Cary
