The Clubhouse If it doesn't fit in any other category and is about general RC stuff then post it here at the Clubhouse.
size matters!
Old 06-10-2002, 05:30 PM
FIVESQUARE
Banned
Default fuel lines
I did not go take my cowls off Any OF MY AIRPLANES...but I think the muffler goes to pressure, and my crankcase has a screw installed to block vent. (in the line)
Doc
Old 06-10-2002, 05:51 PM
FIVESQUARE
Banned
Default fuel lines
I will go out to the shop now to check...It will take me a few to get back, I have to remove one of my cowls to check...
DOC
Old 06-10-2002, 06:05 PM
FIVESQUARE
Banned
Default Fuel lines
My block line extends about 2" and is blocked by a screw.....
The pressure line goes back to the tank.......(from the muffler).The fuel line goes to the carb.I have a pressure dot to fuel.......
Hope this helps.......This is on a Saito 100.....The 72 is one I do not own......I suspect it is the same........Do you have a book???
Good luck,
DOC
If I can help let me know.......I have a book on the 100.....I suspect all Saito's are the same....
Regards,
DOC
Old 06-10-2002, 06:20 PM
FIVESQUARE
Banned
Default Lines
Glad to help......
Doc
PS I leave the plugged line inside the cowl....That is why I couldn't see it...
Old 06-10-2002, 06:34 PM
FIVESQUARE
Banned
Default reviews
You can try in your search engine.
Thunder tiger rc
Thunder reviews rc
Sorry, I don't own a tt......
Doc
PS...Good engine I understand...very reliable and a good idle....
Good luck...Doc
You might try ehobbies TTR4532 for reference. That is your cub...
Old 06-10-2002, 06:47 PM
FIVESQUARE
Banned
Default j3 cubs
You can rest assured the J3 cub will make you proud......She gets a little "sassy"on take-off...but fun to fly she is..........
I have had one since the new age of my RC....
The one that isn't for sale EVER is my cub.....I do hope you have experience before you fly...It is not one to learn on.....Just a fun ole girl....
Doc
Old 06-10-2002, 07:04 PM
FIVESQUARE
Banned
Default Base to final
Most pilots like left traffic....that is making left turns......
Try this:
square all your turns as if you are flying full scale......
When you are downwind...make your left turn and "square" it to your final....turn you airplane over your left shoulder...it will look wrong, but do it.....
You will find you fine tuning on final will be a easy chore....Don't let you tail get under your airplane...keep the tail high..and adjust with throttle ...use rudder as needed...remember...prop up the wing with your stick....always turn your rudder away from the pitts...
you will do fine...
Doc
Old 06-11-2002, 05:29 PM
FIVESQUARE
Banned
Default Saito 72
Wreckman said what I said.....
Mine is blocked.....since I have owned the airplane.
Doc
Old 06-15-2002, 05:45 PM
tailskid
My Feedback: (34)
tailskid's Avatar
Default size matters!
Mine doesn't like a 4" extension on the crank vent...maybe I'll try a 2" piece of fuel line and see if it likes that!
Jerry
Old 06-16-2002, 09:24 AM
tailskid
My Feedback: (34)
tailskid's Avatar
Default Saito 72
No, the engine just runs erratic with that tube on. Took it off and without touching the needle valve, the engine ran great!
Jerry
