Need Control Connector Kits for "Plug-in" Stabs
My Feedback: (90)
I am looking for some kits to hook up controls on removable stab with the servos inside the fuse. Byron used to use something similar in their Warbird kits with plug in wings and stab. It is basicly and arme with with a shaft that slips inside a bushing, and mounts to the fuse. When the stab is inserted, there is a stub shaft on the elevator that plugs into the horn assy.
I have search all over the net for something like this.
My Feedback: (90)
RE: Need Control Connector Kits for "Plug-in" Stabs
I found a couple of pics that show what I am looking for. These are thr Byron pieces, and the pics were kinda "pirated" from the Byron P-47 build thread in the Warbirds forum.
NM
Look at ball links for model aircraft use, or ball links for model helicopter use. If you opt for the helicopter type, then get the removal tool to go with them, and they'll pop right off. The car guys also use a spring loaded type of ball link for attaching to their steering gear.
> Jim
> Jim
