Refilling plane gas tank?
My Feedback: (7)
I have a gas tank in my plane that the only way to refill the fuel is to take off the carb nitro line and use a hand pump. Instead of always pulling off the nitro line to the carb how do I put another line coming out of the gas tank? Thanks!
My Feedback: (12)
SC
RE: Refilling plane gas tank?
If you have access to the carb, just pulling the line is the most common and simplest way. However, if you want, you can go to a three line fuel tank setup. The third line would have a plug that you would remove to fill the tank. I attached a drawing to show what the tank would look like.
Hi Moe142,
Either a filler valve or fuel dots will solve this problem. However if you have easy access to the carb fuel line I would stick with your current method. It's the one I use unless the model has a cowl then I use a Dubro filler valve. Some prefer the dots as based on the KISS principle there is less to go wrong and no parts to loose.
Cheers,
Colin
Cheers,
Colin
My Feedback: (24)
GA
You can use a fuel dot. This is a plug that goes into a third line on your fuel tank. This line usually has a clunk on it as well. If you are using a gasoline engine you can tee off the carb line with a fuel dot.
