How do you land?
NJ
How do you land?
Thinking of my flying (haven't got out in a while so I'm craving for some flight time) I was noticeing that for me it feels more comfortable to land by touching the closer main gear then settling down on the rest.
what about the rest of you? do you like to touch one main, all three, just the mains?
How do you land?
Agree with Tedster - depends entirely on the model.
With a trike, I'll always land mains first; with a taildragger, it varies enormously. With a new model I try all types of landings, and use whetever works best for that model. For instance, my Ultimate bipe lands best (for me anyway) in a three-pointer; my mini-hots behaved best when landed on the mains only, with the tail held up to the point where it was horizontal (incidence-wise); my Su-26 lands best when landed on the mains with the tail being held just slightly tail low on the approach, then released to go tail-level right at the moment of touch-down.
Each one has its own traits.
Gordon
Gordon
My Feedback: (8)
WY
Depends
I usually set the avistar down on all three at once.
But depending on the cross wind it could be wing tip first then one wheel then the other wheel then the other wing tip and back and forth until all three wheels finally take hold as the speed bleeds off slowly and the plane becomes stable enough to breath again.
later Jim
later Jim
How do you land?
There is another option...comming from a combat pilot...and that's skidding on the belly without landing gear. However, living in Kansas with an average 20 mph wind...most of our landings are just "plop" weather on the belly or the gear
NJ
How do you land?
i thought you just let go of the sticks and let them fall out of the sky.... i didnt think you would take time to LAND those things
How do you land?
NJ
How do you land?
looking at the poll so far I am the only oddball that does 1 point landings .. hmmm :bananahea
if you want to see what I mean look at this vid
http://www.rcuniverse.com/magazine/r...tintofland.wmv
My Feedback: (22)
How do you land?
I will land with the upwind main first sometimes. But usually if it is a slow plane and there is a strong crosswind. That big H9 Cub is a ball to land in a slip. However, if the plane is fast, I can't think fast enough to land in a slip unless I've been doing it alot lately. i have a Cap232 and I'll slip it sometimes, but only if there is a very strong crosswind, otherwise I'm too lazy!!! Can I pick two answers?
