GP 60 Cub tailwheel
CA
GP 60 Cub tailwheel
I got an email through RCU from a choochoo3538@somethinerother As follows
Great looking plane,I have the same one that I am putting together. Can you tell me what tailwheel assembly you are using. The one that comes with the plane is junk as you probably know
Tried to reply JJ but it doesn't work [:'(]
yea the original tailwheel is junk aesthetically and functionally, that is why I didn't use it.
I ended up with the Goldberg tail wheel since at the time I couldn't get ahold of the GP scale gear Which I still think is a better unit
This is what's on it.
[link]http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXHBP5&P=0[/link]
Works OK. I had some binding issues when first installed. I've redone the linkage so the pushrods between the rudder and tailwheel are aligned. a ball link would help as well.
I recommend and wanted to put it on in the first place
0
[link]http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXCLK9&P=0[/link]Hi
