RE.servos--&Giant scale arfs.
i have had this happen in the past you probably have some servos that were not assembled correctly loosen the case screws wiggle the cases to center them and then retighten the screws evenly then retest if they still hang
up send them back ,the problem usually is due to surface mount technoligy when the case is not tightened
correctly it puts the pot in a bind causing erratic control
