Yellow Aircraft covered in Monokote?
My Feedback: (44)
Or so their ads say. After doing a little wrinkle touch up on my new 30 Sukhoi, I found out that the covering has a clear adhesive, and that the seams will pull if you get them to hot.
All the Monokote I've ever used has the distinct quality of being vertually unbondable at the seams, once two layers adhere. Monokote has traditionally always had the color mixed in the adhesive on the backing.
Just be real careful if you pull out the heat gun before going to the field. Otherwise, the covering job seems excellent.
Kevin
Kevin
