K&B .40
OH
K&B .40
Hi Guys, Urgently need help. I have a Sig Kadet LT-40. The problem I'm having is with the K&B .40 it has on it, as well as a fuel problem. To start with, the needle adjustment screw is set at 4 1/2 turns out. When I throtle out the revs do increase, but not for long. It then boggs down and then stops. If I restart it, when trying to turn the needle either way (counter clock ways or clock wise to re-adjust) it starts to peak out and again it seems to get too much fuel again stopping the engine. It is using excessive fuel no mater wich way I adjust the needle. When flying with the best adjustment I can get, I get a dead stick every time. Now here's one more problem, While running or turning the prop to prime the engine, I'm seeing bubbles in the fuel line. Pleas help me with any advise, Thanks in advance >>>-> Bill
My Feedback: (108)
RE: K&B .40
It sounds like you have an air leak in either your fuel lines or your fuel tank. You should remove your tank and check for leaks at the plunger and replace your fuel lines. With air going into the engine, you will never get it adjusted correctly. Fix the air leak and then try to adjust it. Good Luck, Dave
1 Post
RE: K&B .40
yep, no doubt an air leak.
reaplce the fuel lines if possible (or check the old ones for damage) as even a pin ***** can let air into the system
after that, return to base settings and try again
