FYI Los Angles area
FYI Los Angles area
Twitter.com/amagov
Posted 4/16/10
A new FDC NOTAM/TFR has been issued for the greater Los Angeles, CA area beginning Monday, 4/19, at 5:01p until 11:00a PDT, Tuesday, 4/20. The TFR is issued for security purposes to cover VIP movement in this area. Model aircraft operations are prohibited in this area during the specific times of the TFR. Please note that TFRs are subject to change with very short notice. Check back often for the most current NOTAM/TFR information. Timely alerts are also available on the web or on your cell phone at: Twitter.com/amagov.
See the link to the TFR below for more detailed information regarding the restrictions:
Area 1 (4/19, 5:01p – 4/20, 11:00a PDT)
(35nm radius from Latitude: 34º01’22”N, Longitude: 118º21'06"W)
Area 2 (4/19, 5:01p – 6:00p PDT)
(10nm radius from Latitude: 33º56’33”N, Longitude: 118º24'26"W)
Area 3 (4/19, 5:15p – 9:30p PDT)
(10nm radius from Latitude: 34º00’51”N, Longitude: 118º17'16"W)
Area 4 (4/19, 9:00p – 4/20, 10:30a PDT)
(8nm radius from Latitude: 34º03’27”N, Longitude: 118º25'25"W)
Area 5 (4/20, 10:00a – 11:00a PDT)
TFR - 0/5813
TFR - 0/5813
Map View of the Affected Area
Posted 2/17/09 (Indefinite)
A NOTAM has been issued in regards to the Washington DC Special Flight Rules Area (SFRA). In the interest of National Security the FAA has codified special flight rules and flight restrictions for certain aircraft operations in the Washington, DC Metropolitan Area. The new rules and the NOTAM go into effect on February 17, 2009 and remain in effect until further notice. Model aircraft operations are prohibited in the inner portion of the SFRA known as the Washington Metropolitan Flight Restriction Zone (FRZ). TFRs are subject to change with very short notice. Please check back often for the most current NOTAM/TFR information. Timely alerts are also available on the web or on your cell phone at: Twitter.com/amagov.
See the link to the NOTAM and the Map View of the Affected Area below for more detailed information regarding the restrictions:
FRZ - Approx, 15nm radius from Latitude: 38º51’34”N, Longitude: 077º02'11"W
The DC FRZ is that airspace depicted beginning at Latitude: 38º59’31”N, Longitude: 077º18'30", thence clockwise along a 15nm arc from the DCA/VOR (Latitude: 38º51’34”N, Longitude: 077º02'11"W) to Latitude: 39º06’28”N, Longitude: 077º04'32"W, thence southeast via a line drawn to Latitude: 39º02’18”N, Longitude: 076º50'38"W, thence south via a line drawn to Latitude: 38º59’01”N, Longitude: 076º48'32"W, thence clockwise along a 13nm arc from the DCA/VOR to Latitude: 38º50’53”N, Longitude: 077º18'48", thence north to the point of beginning, excluding the airspace within a 1nm radius of Freeway Airport, Mitchellville, MD. The FRZ is within and part of the Washington Special Flight Rules Area (SFRA).
NOTAM - Washington DC Metropolitan Special Flight Rules Area
Map View of the Special Flight Rules Area
Posted 4/16/10
TFR - 0/5813
TFR - 0/5813
