Composites Fabrication And Repair Carbon Fiber, Kevlar, Fiberglass and all the newest high tech composites
Balsa under Glass/Epoxy
Reply
Old 11-17-2010, 10:46 PM
joe_crash
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Balsa under Glass/Epoxy
Hello everyone,
I'm very new to this aspect of the hobby. Iwould like to glass either one of my foamies, or a all balsa bird, sand fill repeat, just to get that finish that looks so good in a composite frame.
Can anyone reccomend any online sources of glass/resin/hardner? And does Resin have a shelf life?I have a can of it in my garage, but think it is over 5 years old - I guess I'd be better off getting some new resin, huh?(seems a no brainer once Ityped that out).
I have heard and read an article about building a F5B power soarer (I think it is F5B) where in the article he stretched a kevlar or glass sock over the fuse, glassed it, (left the nose open), poured in acetone to disolve the foam and ended up with a completely composite frame. Would this work?
joe_crash is offline
Old 11-18-2010, 08:37 AM
CloudyIFR
CloudyIFR's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Balsa under Glass/Epoxy
I like JGreer epoxy:
http://www.jgreer.com/
300/21 works fine. I heat cure all my parts with an electric heat blanket. I wrap the part in the blanket about 3 hours after mixing up the epoxy and allow it to cure for about half a day. This gives much better results and JGreer recommends heating 30 degrees F. above the intended use.
West Systems is probably one of the more popular brands:
http://www.cstsales.com/west_system_epoxy.html
I can't attest to shelf life of epoxy.
The sock method works great:
See: http://tailwindgliders.com/Video2.html
Curtis
Montana
CloudyIFR is offline
Reply
Display Modes
