metric wing tube?
RE: metric wing tube?
soarrich, Thanks anyway for the suggestion. I did find a company that carries a close enough replacement however it's a little pricey for a 60/90 size ARF! www.carbonfibertubeshop.com They have a 60 inch .700"(OD) tube that is close enough. (18mm is .708"). About $80.00 shipped[X(] I'm still researching though.
soarrich, The two tube idea did cross my mind but I didn't give it much thought. I think you may have provided the incentive to try it. The Troybuilt carbon tubes are 18mm with a .9mm wall thickness giving and inside diameter of about 16.2 mm or .64 inches. A 5/8 inch aluminum tube is .62 inches (OD) Pretty close. Maybe a 4" or so piece of the aluminum tube well slathered with JB Weld would work?? The price sure is reasonable @ 2x$14.95 plus a couple bucks for the aluminum! Do you think it will hold together? I know my carbon fiber pushrods have stood the test of time with the same method of attachment although the stress factor would be different. Worth a shot as I've run out of options. I just talked myself into it and am ordering the tubes now...
