Composites Fabrication And Repair Carbon Fiber, Kevlar, Fiberglass and all the newest high tech composites
Bags for bagging
Reply
Old 12-09-2010, 03:25 PM
thunderchief
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Bags for bagging
Does anyone have a source for very large bags that can be used for bagging? Or has anyone tried making their own? I need to bag an 80 inch mold. Putting stretchlon over the opening of the mold and pulling a vacuum did not work well...to many leaks since the mold was not designed from the start to be vacuumed.
thanks
Glenn
thunderchief is offline
Old 12-09-2010, 03:51 PM
Pitts S1S
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Bags for bagging
I've used 1 mil Visqueen from Home Depot. Fold it in half then use some Rope Caulking to seal the edges together. It worked on some smaller molds. Should work on a large one.
Jeff
Pitts S1S is offline
Old 12-09-2010, 07:38 PM
vicman
vicman's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Similar to me. 3 mill and the cheapest caulk I can buy. Works great.
vicman is offline
Old 12-10-2010, 10:25 AM
diggs_74
diggs_74's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: vicman
Second that.
diggs_74 is offline
Old 12-10-2010, 11:30 AM
MTK
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: vicman
I roll plumber's putty into a string and use it to seal edges. Works great and allows bag reuse. Not messy at all
MTK is offline
Old 12-10-2010, 01:31 PM
Champ-RCU
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'll Third the use of 1 to 3 mil plastic and chalk. The only other process I use with these is I wipe down the areas where the chalking is placed (i.e. around the outer edges) with grease and silicone remover. Like what an auto painter would use. I seem to get fewer small air leaks when I remember to wipe the plastic down.
Good luck
MTY
Champ-RCU is offline
Old 12-11-2010, 04:45 AM
Bundubasher
Bundubasher's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Try the plastic "heat shrink shroud " that is used for industrial pallet covering. See pics.
It is a contineous plastic sleeve (tube) on a roll and you cut off the correct length and pull it over the pallet, then heat shrink it. They come in various thicknesses from 20 - 150 micron.
You probably want to go for the thinner gauge i.e.30 micron or so. Insert your piece, seal off both ends and Bob's your uncle......
Bundu
ID:	1532778   Click image for larger version
Bundubasher is offline
Reply
Display Modes
