Composites Fabrication And Repair Carbon Fiber, Kevlar, Fiberglass and all the newest high tech composites
hydrocal molds - finishing
Reply
Old 12-15-2010, 11:07 AM
oddy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default hydrocal molds - finishing
Hello everyone.
I´m making hydrocal molds to produce my airplanes fuselages
After having finished the hydrocal mold and demoulding the pink foam piece I seal the hycrocal with 3 or 4 layers of epoxy resin.
Anyhow when taking out of each layer the excess of epoxy, it tends to leave some marks on the epoxy finishing which of course does nont allow a perfect surface.
Any recommendation on how can I seal all this imperfection for achivieng a better finishing surface for my molds would by very much appreciated.
Kind Regards
Oddy
oddy is offline
Old 12-15-2010, 11:42 AM
soarrich
My Feedback: (98)
soarrich's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: hydrocal molds - finishing
ORIGINAL: oddy
What do you mean by taking out each layer of excess epoxy?
When I put the epoxy onto the Hydrocal I just brush it in, then let it set for a minute, then wipe it out, the only epoxy left in the mold is in the hydrocal. If after 3 applications of epoxy there is any excess, I guess you should sand it with 1000 grit, paper, then maybe buff it with a polishing compound. The molds I made where smooth after the epoxy though.
soarrich is offline
Old 12-15-2010, 11:53 AM
oddy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks a lot for your help.
Probably whats going on is that I´m not wiping out all the excess and marks of the paper im using to wipe out are being left of the surface.
Ill be trying with the 1000 grid.
Oddy
oddy is offline
Old 02-05-2011, 01:28 PM
wyowindworks
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Have you guy heard of ES-221? Instead of sealing the plaster after the mold is made, you brush this onto the plug and then pour your plaster on top of it. It's call a PFP mold....plastic faced plaster. The downside it that you can't do the "pour straight onto foam" trick.
File Type: pdf
wyowindworks is offline
Old 02-28-2011, 03:00 PM
BilleFly
BilleFly's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ultracal 30
will work also , in place of your Hydrocal.
It is not quite as brittle as the one your using
and has a tad more compressive strength.
Also,(and MOST importantly)
The % expansion rate at setting for the
Ultracal-30 is only 0.08;
where-as the Hydrocal is 0.12 %.
Ultracal-60 is only 0.07 %-but i Never have the patience to wait !
-Hydrocal will work just Fine though.-
Are you using Manila fibers for strengthening, or some other suitable fiber ?
By the way PFP molds ARE the way to go. I did a post on how to make them over
on rcgroups and had a 66.6%. "Negative reaction", from people wondering WHY
a mold that can be heated to 300 degrees with near O distortion rate would be suitable. ...
so i Deleted the post on topic.
Bille
BilleFly is offline
Old 03-19-2011, 01:10 PM
CoosBayLumber
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Back in my boat building days, used to be handed a vac-u-formed plastic hull and told to make X copies of them. Would mount the half model to a big formica covered board, then seal the edges with free common old Bee's wax from a local paper cup place, and then lay on the Plaster of Paris (as it was cheap at less then $1 per bag) which stayed cool and then would not heat up and warp the thin plastic.
Sanding? Well that went rather quickly, and details? I did not notice the scratch in the plastic there before.....
Wm.
CoosBayLumber is offline
Old 04-18-2011, 06:10 AM
Arbo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Billie,
I'd be interested in hearing about the ultracal molds. Process to make them, are they as good and tough as epoxy molds? Is it a wax prep for release? etc....
Paul
Arbo is offline
Old 04-18-2012, 04:54 PM
breesheamua
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The process for making an ultracal 30 mold will be pretty much the same, ultracal is a much harder stone and can be baked but takes much longer to cure or set up. Do release these as well as you would any other mold. can't compair them to epoxy molds.
I'm suprised to see no one has drilled keys into their molds so they line up and close tight, i found this forum while searching for a troubleshooting issue with a cast i'm making for a prosthetic piece. How do you guys go about making your stone molds and what do you build the molds off of?
breesheamua is offline
Contact Us Archive Advertising Cookie Policy
