Cab-O-Sil & Micro Balloons
Working on the repair and redo of glass-work bonding wood frames to glass fuselage
and re-installing a few reinforcement bulkheads and formers on a Byron 33% RV-4.
From what I can tell the fuselage is a polyester resin product. My question is not
having access to "Cab-O-Sil" ,as there are no fiberglass shops nearby, would micro
ballons do the same thing when mixed with ther ployester resin?
Bill D.
Bill D.
CA
RE: Cab-O-Sil & Micro Balloons
In reinstalling bulkheads you need the strength and usually you only use a mix of micro balloons and resin as a light weight filler. Usually you use flox and resin as a stiff glue.
Just my 2 cents.
Just my 2 cents.
FL
Cab-O-Sil or sometimes called Fumed silica is a thickening agent for resins. It is mainly used to keep the resin from flowing to much when you are placing it on a vertical surface. The micro balloons or glass spheres lighten the resin by filling the space with air, but weaken the resins overall joint strength.
To reattach a bulkhead, I would add some milled glass, chopped glass, cotton flock or some other sort of strengthening material. If you don't have any of these available, you can take some fiberglass cloth and cut it up with a roller cutter (like mincing it up) into a "milled glass" and add this to the resin for some additional strength. Make sure you sand and roughen up the area in the fuselage where you intend to attach the bulkhead and clean it with a solvent well so that you get a good adhesion joint.
My intention of using the cab-o-sil was in tight corners to avoid air pockets
when re-attaching the formers that have come lose because of the air cavities
that are present form the original builders not working them out of the resin in the
initial attachment of the fuselage formers. My plan was to have a small amount of
"filler resin" at the ready to avoid this happening, but I do agree that milled fiber is
probably a better "filler" and stronger solution than micro ballons or cab-o-sil.
Thanks for all of your comments, progress continues........
Bill D.
Bill D.
Hi Bill
When installing bulkheads in fuses I use a mixture of cabosil and milled fibers in the resin. You can buy both on line from www.fibreglast.com. Cotton flox as stated earlier will work also but it usually is a good idea to mix cabosil also to make it into a thicker paste so it stays put.
Todd
Todd
ORIGINAL: Randy Etken
I chop up Carbon Fiber and add to the resin. Strongest there is.
