How to cut weight of a wing tube ?
ON, CANADA
I have a 85cc Aeroworks Yak....looking to shave some weight from the wing tube (its 9oz).....a CF tube only saves 3 OZ....so I was wondering if you could drill holes in the factory tube to shed some weight ? Is the only load on the tube where the wing meets the fuse ? Is it possible to drill some holes in the middle and ends of the tube, and leave the area where wing meets the fuse solid ?
Anyone try this ?
Anyone try this ?
RE: How to cut weight of a wing tube ?
You could cut holes in the vertical quadrants of the tubes, and not have a big reduction of stiffness, "in theory". CF has very good tensile strength, but it's not so good in shear strength which is the kind of stress that the "webs" between the holes would be subjected to. I would take the 33% weight saving and call it good.
My Feedback: (29)
ORIGINAL: nappy99
Anyone try this ?
Anyone try this ?
