Composites Fabrication And Repair Carbon Fiber, Kevlar, Fiberglass and all the newest high tech composites
Fiberglass cowls
Reply
Old 03-19-2011, 01:01 PM
CoosBayLumber
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Fiberglass cowls
Well, I finally decided to read the whole thing (including captions) and look at the illustrations from an old, old editio of AAM, of Aug. 1974. I am referring to the fiberglass article by Robert Harrah, I chose it as I already have many of the noted items at hand, but am a bit disappointed in it too. For the text goes on and on about the materials, not the illustrations and after number 11 I am lost. Zero on how to lay up a small cowling or how to make anything from beyond a plug and mold.
Is there any better, for I need to make up several cowls, not just one big item? I have built model boat hulls in the past, and these items are even smaller.
Wm.
CoosBayLumber is offline
Old 03-19-2011, 01:06 PM
saramos
saramos's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Fiberglass cowls
Here's a link to Paul Johnson's article on how to make a one off cowl. I'm sure you can find some useful info here.
http://www.airfieldmodels.com/inform...cowl/index.htm
Scott
saramos is offline
Old 03-19-2011, 01:17 PM
CoosBayLumber
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Scott: That article is sort of the Hokey way of doing things. Although not very big, I need to pull several copies and not just the one he mentioned.
Wm
Old 03-19-2011, 03:10 PM
speedracerntrixie
My Feedback: (29)
speedracerntrixie's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Post a pic of what you need to lay up and maybe some suggestions will come forth
speedracerntrixie is offline
Old 03-19-2011, 03:38 PM
mboland
mboland's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have been following a good thread on RCSCALEBUILDER
It is a very long thread but the bits that may help is the builder has done some very good youtube clips of the mould making process he is using that would give you moulds capable of a number of uses.
His youtube channel is at
I am currently trying out his methods on a TF Spit I want to convert from MkIX to MkV
Mike
mboland is offline
Old 03-19-2011, 08:46 PM
saramos
saramos's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: CoosBayLumber
Wm
Oops,
I should have taken a closer look at who was posting the question. Have you checked out the videos that are available at Freemans?
They have videos on silicon molds, laminate molds, vaccume bagging, all sorts of neat stuff. You might find something there.
http://www.freemansupply.com/video.htm
Scott
saramos is offline
Old 03-20-2011, 07:13 AM
CoosBayLumber
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Scott: I got several booklets on castings at Aircraft Spruce in Corona years ago. They essentially say come on in talk to one of our consultants and he will aim you inn correct direction (over to the Composites only aisle)
Mike: A frind of mine and I keep getting kicked off the RCScalebuilder web-site so have not been back in 1-2 year now.
Wm.
Old 03-20-2011, 04:53 PM
Pitts S1S
My Feedback: (9)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here ya go, everything you wanted to know.
http://www.cstsales.com/tutorials/fiberglass_mold.pdf Mold Making
http://www.cstsales.com/tutorials/fiberglass_parts.pdf Laying up the parts
Jeff
Pitts S1S is offline
Old 03-20-2011, 07:20 PM
CoosBayLumber
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Pitts S1S
Jeff
I have most all of Composit Sales literature, as they are all over the place in Corona. Mine are gathering dust, as I do not need to lay up for a 23 foot boat right now.
CS sells a line of epoxy that is rather expensive, and dries like in two weeks. I used it but twice. Which is one reason why I like the older resins. They were fast.
Wm.
Old 03-20-2011, 07:31 PM
amtpdb
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I found a place in Ontario that manufactures and sells many different epoxy resins. I found them on ebay and picked up my order and the ceo spent 1 hour discussing the many different epoxies and there differences. The place is called polymerproducts. They sell many different glasses, carbon fiber, additives, and as I said many different epoxies with different pot life's. They sell 24 once and up sizes. They showed me several of there products while I was there. On eBay they have many videos and information on each of their products pages for sale. Their prices seem cheaper to me. You could find their products and see their attributes by searching EPOXY RESIN in eBay's search if you were so inclined.
Just my 2 cents.
Don
amtpdb is offline
Old 03-21-2011, 07:27 AM
CoosBayLumber
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What part of Ontario? I wonder if they aren't in the new area near to the truck stop in eastern Ont?
Wm.
Old 03-21-2011, 04:20 PM
amtpdb
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Polymer Composites
1871 S Lake Place
Ontario, CA 91761
909-673-1625
amtpdb is offline
Old 03-22-2011, 11:02 AM
CoosBayLumber
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am wondering,,,,,
Is that lake street address on East side of town (nearest us) or on the west of south side? Wonder too if they took over any Hastings projects?
Wm.
Old 03-24-2011, 04:22 PM
Avaiojet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I make my cowlings easily.
I shape them out of foam then lay glass cloth over the foam. This is called "The lost foam method."
It's been around for many years.
When my foam is shaped, I remove another 1/16 if an inch to allow for the build up of cloth and glass.
The foam is removed from the laid up glass with acetone. The glass cowling is finished sanded.
I only use Polyester laminating resin. Reduces with acetone. A QT can be purchased at your local body shop supply house. Maybe 15 to 20 bucks?
Nothing hard about any of this. Well, you do have to carve and shape the foam, but sandpaper can be used for the final shaping.
I made this cowning for my 1/5 scale Gee Bee Z, and the sholder area of the 1/3 Gee Bee Z is foam with class covering.
ID:	1583703   Click image for larger version
Avaiojet is offline
Old 03-24-2011, 04:56 PM
wyowindworks
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Avaiojet
What kind of foam are you using? Are you covering it with something? Polyester resin typically melts XPS and EPS foam.......especially when reduced wtih acetone.
wyowindworks is offline
Old 03-25-2011, 11:30 AM
Avaiojet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Contractor's pink foam.
I shape it as close as I can get then apply a coat or two of two part epoxy. This seals the foam. (forgot this part.)
I scratch it up with 220 grit paper and clean. The rest is Polyester resin and cloth.
I've never done this, but if it's a complicated cowling, parts can be made of balsa and epoxyed to the foam.
Avaiojet is offline
Old 03-25-2011, 03:27 PM
CoosBayLumber
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
As mentioned above. Need several of. Not just the one you are describing.
Wm.
Old 03-28-2011, 05:26 AM
Avaiojet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Several of the same or different.
You won't get them if you don't make them. The shaping is the hardest part.
Photos?
Charles
Avaiojet is offline
Contact Us Archive Advertising Cookie Policy
