Composites Fabrication And Repair Carbon Fiber, Kevlar, Fiberglass and all the newest high tech composites
My One off Cowl build
Reply
Old 06-28-2011, 10:32 AM
chip_MG
My Feedback: (14)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default My One off Cowl build
Hey All,
Thought I'd post a couple of shots of my Bud Nosen Citabria cowl.
A little foam board epoxy glass and resins.
Oh what fun.
I did'nt really like the wood version as per the kit., so
ID:	1628860   Click image for larger version
ID:	1628861   Click image for larger version
ID:	1628862   Click image for larger version
ID:	1628863   Click image for larger version
chip_MG is online now
Old 06-28-2011, 05:45 PM
Avaiojet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: My One off Cowl build
Looking good!
A bit of sanding, maybe some microbaloons and you'll have a great cowling.
Although not as difficult, I made this cowling the same way. I used Polyester resin.
Avaiojet is offline
Old 06-29-2011, 09:00 AM
soarrich
My Feedback: (98)
soarrich's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Good job.[sm=thumbs_up.gif][sm=thumbs_up.gif]
soarrich is offline
Old 07-02-2011, 01:53 PM
chip_MG
My Feedback: (14)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thx charles and rich,
yea, I guess I should have put off this post until I finish it..
I'll post an other pic when done.
I have made a dozen or so cowls, pants and other FG items using this method..
It work well, is fast and best of all, cheap.
happy landing ya'll
Chip
Old 07-28-2011, 02:09 PM
chip_MG
My Feedback: (14)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A shot of my progress..
It's a will soon be flying.. hope .. hope
Happy Landings Ya'll
Old 07-28-2011, 03:14 PM
Avaiojet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
WOW! Can't beat it, looks great, nice plants!
Avaiojet is offline
Old 07-28-2011, 03:49 PM
chip_MG
My Feedback: (14)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thx Charles,
Did you say once you have used Poly resin for your projests?
I have not used polyester for some time, I like the West System epoxy, but it is a bit high priced , and slow to cure..
Happy landings Ya'll
Old 07-28-2011, 06:53 PM
soarrich
My Feedback: (98)
soarrich's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: chip_MG
You're using the 205 hardener? Try the 207 it goes a lot quicker. The have a Fairing compound that sands nicely too.
soarrich is offline
Old 09-24-2011, 05:21 PM
Prboz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dumb question coming "What is foam board?" Is there a more tech name for it?
Prboz[:-]
Prboz is offline
Old 09-27-2011, 11:07 AM
chip_MG
My Feedback: (14)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
the foam board I used for this is a 3/4 inch sheet 4' X 8' I got at home depot. I think is was $6.95 per sheet.
I glue it togeather with 3M77 spray also from home depot.
Old 11-06-2011, 06:25 PM
ezflyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
foam board is an insulation board that is used behind paneling or sheet rock or metal. you can buy it a just about at any hardware store. comes in a 4x8 foot sheet. great for makeing molds of any sorts.
ezflyer is offline
Old 11-11-2011, 07:44 AM
Mk23socom
My Feedback: (7)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ok, so the lay-up is done over the mold, is there something coating the foam mold to keep the cowl from sticking to it? or do you just bust it out and toss away the rems?
Mk23socom is offline
Old 11-11-2011, 08:27 AM
soarrich
My Feedback: (98)
soarrich's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Mk23socom
The way I do it is to cover the foam with packing tape, mold the piece, then pour some gas on the foam. The foam melts and the packing tape lets you take it out of the cowl neatly.
soarrich is offline
Old 11-27-2011, 03:43 PM
golf4two
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: soarrich
ORIGINAL: Mk23socom
I have used a couple of layers of regular kitchen cling-wrap to coat the mold. After cure it is easy just to pop out the mold pretty much intact for future use.
G42
golf4two is offline
Old 02-13-2012, 05:59 PM
blackdog1961
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ok guys. You are obviously really experienced with this so please indulge some beginner questions. I have done a little bit of fiberglass work and have not been happy with my work because of wrinkles.
With this kind of complex plug with many compound shapes, do you do the layup with multiple narrow strips or is there a trick to getting a larger sheet to follow the curves?
How many layers do you use?
blackdog1961 is offline
Old 02-14-2012, 07:15 AM
chicks5
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Can the foam be glued into a hole on a existing cowl and used as a plug? Then finished and sanded?
chicks5 is offline
Old 02-14-2012, 03:38 PM
chip_MG
My Feedback: (14)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Chick5,
I used 3m 77 you can get at the Home depot to glue the sheets together with. The foam board itself comes in 2' X 4' sheets or 4' X 8' sheets I think is was around $8 a sheet for the 4x8 size. It has other uses as well, in the hobby.
Blackdog, sorry for taking a long time to respond RCU has become so slow that I don't come here as much anymore..
But I'll outline the process I use to make a single item the cheapest that is.. If I need duplicates like wheel pants then I'll make a plug , and mold but doing that cost about 3 times the money and time.. Thats why Use the one off method for single items like cowls.
First cut the sheets to close size maybe 1/2 " larger all around to save sanding later. Use the plan profile to get the shape ya need, then glue the sheets together using 3m77..
Then sand to shape using course 30 - 50 grit sandpaper on a block. Use you plans to get the shape right. I make 3 cardboard templates for this one for each view.
When ya got the plug the shape you pleased with, then you just cover it in fiberglass glass using EPOXY resin,, Don't use poly or it'll eat the plug fast.. Polyester resin attacks most type of foam. Plus Epoxy resin in easier I think.. I cut the fiberglass 5 Oz type as large as I can get it to lay on the plug without pulling up.. It does'nt really matter because you'll be sand the fiberglass back to finish it anyway. I usaully will use 2 - 3 layers of 5 oz glass because I like a strong cowl.. If you sand a hole in the cowl It's no big thing cause you can always all more glass.. When your sanding use a dust mask and go outside, It can be messy.
After you happy with the thing, drill a large hole and put acetone or MEK to melt out the foam, also messy.
Thats it, after ya make a few things it'll get easy and you can learn to not be as messy..
Cheers, and happy landings to ya
Chip
Old 02-14-2012, 08:58 PM
soarrich
My Feedback: (98)
soarrich's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: chicks5
I've plugged a hole in the cowl, but the other way around.
First I used a piece of mylar on the out side of the cowl, then put glass on the inside of the hole and cowl. The mylar leaves a smooth surface on the "plugged part" with very little finishing needed.
soarrich is offline
Old 02-14-2012, 11:42 PM
chip_MG
My Feedback: (14)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes, You can use an exiting cowl as a mold. I have done that from kits when there where kits to build that is , only a few left.. There is not much varity anymore for kits so I like building from plans. Its slower of course but I love to build stuff.. Most of the kits used to have abs plastic cowls, they'er not too tuff so one noseover on the pavment and a cracked cowl you'd have. Fiberglass ones can be alot stonger..
Contact Us Archive Advertising Cookie Policy
