Composites Fabrication And Repair Carbon Fiber, Kevlar, Fiberglass and all the newest high tech composites
carbon fiber tape
Reply
Old 07-10-2011, 09:22 PM
seattle_helo
seattle_helo's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default carbon fiber tape
Looking for a good source of carbon fiber tape in small quantities. Ideally something like a 2" width that's 6' long. Seems to be a lot of suppliers of large rolls but can't seem to find any small stuff. Any suggestions?
seattle_helo is offline
Old 07-23-2011, 10:42 PM
aethertek
aethertek's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: carbon fiber tape
http://www.acp-composites.com/home.php?cat=4806
Kevin~
aethertek is offline
Old 07-24-2011, 08:45 AM
seattle_helo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have found a few other sources but didn't know about ACP so that's great. Good prices too. Thanks for that, Kevin.
Old 07-24-2011, 10:24 AM
wyowindworks
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Are you looking for woven tape or uni-directional tape?
Here is another option: Soller Composite UD Tape and Biaxial Tape
wyowindworks is offline
Old 07-24-2011, 05:52 PM
seattle_helo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm not certain but I think woven. I'm looking to reinforce 90 degree corner joint areas of fiberglass to fiberglass and fiberglass to wood formers. I was hoping to get some CF tape that was in the same configuration as fiberglass cloth.
Old 07-24-2011, 09:44 PM
wyowindworks
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: seattle_helo
In these situations glass can sometimes perform better due to it's higher strain characteristics. Why use carbon? If the rest of the structure is glass why not just use glass?
Old 07-24-2011, 10:13 PM
seattle_helo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Please understand that I'm not familiar with any of this very well. My understanding was that CF would give me more strength and more rigidity over fiberglass. Is that incorrect? If so, what would be a good use of CF tape or cloth?
Old 07-25-2011, 08:03 AM
JRgraham
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: wyowindworks
Im no scientist, but Iwould use the Carbon Fiber in the areas you mentioned too... More important than the fiber [match] here, Ithink you really want to make sure you match the glue agent used. If your laminating anything to exsisting fiberglass, use the same agent the fiberglass has already; Epoxy to epoxy, or glass resin to resin. (someone may argue or add to this)
Although wyowindworks is correct, there is probly no reason to use carbon to reinforce an already glassed area. Some triangle stock, and another layer of glass cloth would be sufficeint. Carbon looks nicer though and is by all means, stronger.
JRgraham is offline
Old 07-25-2011, 10:04 AM
wyowindworks
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Shimano
If the structure fails in some other area besides the joint, then making a stronger joint won't create a stronger structure. Carbon is stronger for it's weight (tensile & compression) and stiffer so in theory one could build a lighter joint ouf of carbon. In reality this doesn't always pan out. For example: 2.2 ounce 1K carbon isn't strong enough and 5.7 ounce 3K carbon is stronger than neccessary. 3 ounce carbon is unavailable. 4 ounce s-glass is strong enough (structure fails before the joint). Which material can be used to make the lightest sufficient joint? The glass.
Also the stiffer carbon joint can localize the stress in the more flexible glass laminates right at the edge of the carbon overlap. This stress riser can propogate an early structural failure. A properly constructed glass joint, with it's better strain properties, can allow the joint/structure to flex so the stress is more evenly distributed throughout the entire structure.
Carbon, though stronger, is also more prone to fracturing when impacted than glass. You could always just do some simple tests to see which performs best. The testing should be done on the entire structure under it's intended use not just a direct joint test. Again, the point isn't to make the strongest joint but rather the strongest structure.
Epoxy will bond better to cured laminates regardless of the resin used to make the laminate. Polyester can have bonding issues even to itself. Epoxy will also handle the strain in the joint better than polester.
Reply
Display Modes
