Composites Fabrication And Repair Carbon Fiber, Kevlar, Fiberglass and all the newest high tech composites
How many layers of 4.25 ounce glass is needed for a cowl
Reply
Old 08-17-2011, 07:19 PM
flyingagin
flyingagin's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default How many layers of 4.25 ounce glass is needed for a cowl
Any suggestion on just how thick or how many layers of 4.25" glass cloth I will need to have a usable cowl?
I am just about to start a fiber glass engine cowl. I already have the foam mold made. I need to seal it with white glue yet. Once I dig out all the foam the then the white glue can be dissolved out in a pan of water.
I have 4.25 ounce glass cloth. As a test I laid two layers down on a waxed flat surface and worked the epoxy (30 minute) thru. It has cured about 8 hours now.
Lifted the panel and it is very flexible and weak. It will take more than that to make a descent cowl.
Any suggestion on just how thick or how many layers I will need to have a usable cowl? It measures about 4” wide by 4.5” tall and is about 5” long to the firewall. It will extend 1” beyond the firewall onto the fuse for a total length of 6”.
The engine (pictured) is a K&B K&B .65 Sportster .65
ID:	1650138   Click image for larger version
ID:	1650139   Click image for larger version
flyingagin is offline
Old 08-17-2011, 08:05 PM
soarrich
soarrich's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: How many layers of 4.25 ounce glass is needed for a cowl
First to answer your question. 2
The epoxy will get a little harder as it fully cures, You are deflecting air not water, it doesn't need to be real strong.
If you use thin packing tape over the foam you can tape it right to the front of your plane, then lay up your glass over the foam and about 1/2" of the fuse, you'll have a perfect fit to you plane/cowl.
soarrich is offline
wyowindworks
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
30 minute epoxy makes for a pretty rubbery part. A true laminating epoxy will make a more rigid feeling part. Also most resins don't start to really polymerize until it cures for 24 hours. In my testing most room cure epoxy resin don't reach maximum stiffness until 6 or 7 days.
I would think that 2 or 3 layers of the 4 ounce would be adequate...unless you dork it a lot. If there is lead in the nose of your plane, then you can do a beefier layup and remove some lead.
Adam
wyowindworks is offline
Old 08-17-2011, 09:15 PM
flyingagin
flyingagin's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks soarrich and wyowindworks
I will buy laminating epoxy and add one more layer
I can always add reinforcement if I need to after the cowl is cleaned up.
The project this is part of is here
http://www.rcuniverse.com/forum/m_10...m.htm#10675596
Old 08-18-2011, 06:25 AM
SCALECRAFT
SCALECRAFT's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Also note that the shape of the glass, like curves ,bends, and humps increase the "stiffness of those immediate areas and help support flat sections. A flat sheet is not the best method to conclude that the glass is too pliable. Also note that your fire wall is really playing a big role in keeping the cowl shape.
As mentioned earlier, correct resins will also play a big role.
I use west systems resin in all my composite models. I have a BF 109 all composite running a fully cowl enclosed nitro engine/muffler and the resin has yet to soften from the heat generated. Even after flight with no air circulating.
You can even look into post curing with heat. this will add additional stiffness. Search online for methods that suite your needs.
Steve
SCALECRAFT is offline
Old 08-25-2011, 07:42 AM
prgonzalez
prgonzalez's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi flyingagin,
I built the cowl of my Giles using laminating Epoxy, WEST SYSTEM. One layer of 2-oz and one layer of 6-oz. Since you have 4-oz cloth, I would use just two layers. The cowl I build has a lot of flights now and the final result was a semi rigid cowl. It is still flexible at the long sides but never rubbery. Flexible enough for not craking or breaking.
My 2 cents.
Pedro
prgonzalez is offline
Old 08-25-2011, 08:57 AM
flyingagin
flyingagin's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey thanks to all the answers. I will use laminating Epoxy, and just 2 layers of my 4.25 ounce cloth. The mold is ready to seal and then lay up. I have a ply nose ring in it.
I ended up having to remake the make the original mold. After much effort I found there were a places that just did not match up to fuse correctly and the lack of a ply nose ring concerned my, so I made a new one. I like the shape of this one a lot more. I changed how I roughed out the foam block. Did it while it was attached to the fire wall. I will say it so far has been a learning experience.
I up dated my construction thread on this airplane to include redoing the mold.
http://www.rcuniverse.com/forum/m_10...m.htm#10675605
Thanks again all for all the help.
ID:	1653369   Click image for larger version
Old 09-25-2011, 06:28 PM
flyingagin
flyingagin's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well I made the cowl. There is still a lot of work to do on it, but here is what I got at this point.
ID:	1666160   Click image for larger version
ID:	1666161   Click image for larger version
Old 09-26-2011, 05:20 PM
blikseme300
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looks good!
Nothing better than reviving an old airplane.
Bliksem
blikseme300 is offline
Reply
Display Modes
