Composites Fabrication And Repair Carbon Fiber, Kevlar, Fiberglass and all the newest high tech composites
uncured polyester resin
Reply
Old 12-23-2011, 06:35 AM
kenh3497
kenh3497's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default uncured polyester resin
I was "fixin" on my Cap 232 cowling a couple of nights ago. I had run out of polyester resin but had some kitty hair left over from a car project. I mixed a batch applied it and low and behold it never set up. I stayed about the consistency of cold peanut butter. I even tried a bit of heat to try to kick it into submission without success. So, I scrapped off what I could but am left with the residue to remove. I know it needs to come off or the new will not bond properly. Never had I had this happen to me. I was really bummed!
As anybody had this happen to them? If so what did you use to remove the leftovers. I tried some brake parts cleaner, which wasn't to successful, but I'm thinking acetone might be a better choice.
New cowling is not available so this one has to be repaired.
Ken
kenh3497 is offline
Old 12-23-2011, 07:26 AM
KC36330
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: uncured polyester resin
Acetone will clean up uncured.
KC36330 is offline
Old 12-23-2011, 07:27 AM
dclancey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Styrene is the only thing that I have found will work.
dclancey is offline
Old 12-23-2011, 07:44 AM
Bundubasher
Bundubasher's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You can paint polyester resin catalyst with a small brush over the area, it will harden the uncured sticky resin - be generous with the catalyst.
Acetone is good for removal but personally I find the fumes affecting me, even with a proper respirator. Putting acetone down the drain is highly toxic- to overcome thisI always clean my PE resin brushes afterwards (for re-use) with a little laundry washing powder. The "cold water type" work even better. Make half a cup of itintoa paste and paint it on the cowl, keep brushing the paste on for 5 - 10 minutes and rinse off with water while brushing- it will be clean and safe. Works very well..
Bundu
Bundubasher is offline
Old 12-23-2011, 06:30 PM
kenh3497
kenh3497's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: dclancey
Interesting, I always thought "styrene" was a type of plastic. I had no idea it was also a solvent.
kenh3497 is offline
Old 12-23-2011, 06:39 PM
KC36330
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: kenh3497
ORIGINAL: dclancey
Interesting, I always thought ''styrene'' was a type of plastic. I had no idea it was also a solvent.
styrene = vinyl benzene = Carcinogenic =
KC36330 is offline
Old 01-12-2012, 08:29 AM
raptureboy
raptureboy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Use the liquid catalyst you get in the tube for resin. I had the problem with a plane I glassed, turned out the stuff was old and past it's date. There are date codes on the tubes as well as the cans of resin. If you use fresh resin and catalyst it will harden up the remainder of whats on there, that's how I fixed my glass job by recoating everything then sanding my butt off.[:@]
raptureboy is offline
Contact Us Archive Advertising Cookie Policy
