Composites Fabrication And Repair Carbon Fiber, Kevlar, Fiberglass and all the newest high tech composites
glass cloth question
Reply
Old 01-26-2012, 06:33 AM
kenh3497
kenh3497's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default glass cloth question
I think I know the answer but would like a conformation.
I purchased some glass cloth (3/4 oz) from Thayer. It is a 56 X 56 weave. I ASSUME it should make no difference which way it is laid on the surface. It should be as strong in both directions. Correct????
Ken
kenh3497 is offline
Old 01-26-2012, 06:46 AM
ByLoudDesign
ByLoudDesign's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: glass cloth question
That's a "Charlie Brown"
ByLoudDesign is offline
Old 01-26-2012, 07:31 AM
dreadnaut
dreadnaut's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
In the case of most glass. carbon, or other reinforcing fibers, there is usually very slight differences in strength fo a given direction of weave. Some fabrics are engineered to have a larger difference in strength for a given direction, but I have not seen this in any thing lighter than about a 3.6 oz. The biggest difference for the process of model building is that these fabrics tend to follow curves better in the "weaker" direction.
dreadnaut is offline
Old 01-26-2012, 07:55 AM
MTK
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: kenh3497
Ken
In general, if you are going to use glass cloth (or carbon, kevlar or other) as a reinforcement or in a composite structure, you would lay the cloth on bias. The reason is simple geometry and physics; hopefully you've had highschool trig where you studied right triangles. You get greater strength in torsion which resists twisting. You have both sets of strands working for you at the same time rather than just one set in one direction and the other set in the other direction
In your case, whatever strength the 3/4 oz cloth adds (isn't much), still works to produce better torsional strength of your structure. Bias layup is particularly useful on wings if you want to maximize resistance to twisting over time. Overall strength addition is low tho because 3/4 oz cloth is light but not particulary strong. Nevertheless, bias laydown maximizes the benefit of whatever little strength you add. Point is if you are adding the weight anyway, why not get the max possible out of the lay-up?. BTW- bias laydown is lay down at 45 degree angle
MTK is offline
Old 01-26-2012, 09:49 AM
wyowindworks
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: kenh3497
That is style #106. It has the same thread count AND has the thread used in both directions. That would make it balanced which allows you to use it in +/-45 applications without warping. Style 2113 (2.3 ounce) on the Thayercraft is NOT balanced. The thread count is close (60x64) but the yarn used in the fill in half the size of the yard used in fill (ECE 225 1/0 x ECD 450 1/0). This is a highly unbalanced fabric that has a near balance thread count.
ORIGINAL: dreadnaut
The subtle differences in the breaking strength of balance fabrics has to the stress that was applied to the yarn during weaving. The fine fill yarns usually get "tweeked" when they are woven.
ORIGINAL: MTK
I'd say it really depends on the application. Bias cut fabric works great on flying surfaces because they need the torsional strength and they usually have a spar to handle the bending loads. The misundstanding is that +/-45 material is stronger in bending because you have twice the amount of fibers being active. Unfortunatly, this isn't the case. Using half the fiber but aligning them with the load is stronger and stiffer than aligning twice the fibers on 45*. Some tests have shown that +/-45 fibers to the loading axis are 1/20 of the strength of those that are parrallel with the forces. The moral to the story is that you need to aligne the fibers with the primary loading axis.
wyowindworks is offline
Old 01-26-2012, 11:07 AM
MTK
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: wyowindworks
ORIGINAL: MTK
Yes I know but thanks for clarifying further to the OP
MTK is offline
Old 01-26-2012, 02:39 PM
kenh3497
kenh3497's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the info... and holding my hand
I will be glassing the whole airplane (CAP 232) I remember the bias layup now that it was mentioned. I think I'll do that on the ailerons. The rudder and elevators are fabric, so no glass cloth there, although I suppose somebody along the line has tried it.
kenh3497 is offline
Contact Us Archive Advertising Cookie Policy
