epoxy mixing containers
I think??? I remember reading someplace to never mix epoxy in a container in which food was stored. I have a bunch of the plastic cups that yogurt came in. The "good" kind not affected by solvents, at least not acetone or lacquer thinner. All have been thoroughly washed in hot soapy water. Before I ruin a batch of epoxy (glassing a whole airplane)..... Use them or not?
Thanks!
Ken
Thanks!
Ken
WY
RE: epoxy mixing containers
For what it's worth, I use all kinds of food packaging as mixing cups. My wife washes them thoroughly. I've never had a problem....and I'm pretty anal about stuff.
My Feedback: (13)
ORIGINAL: kenh3497
I think??? I remember reading someplace to never mix epoxy in a container in which food was stored. I have a bunch of the plastic cups that yogurt came in. The ''good'' kind not affected by solvents, at least not acetone or lacquer thinner. All have been thoroughly washed in hot soapy water. Before I ruin a batch of epoxy (glassing a whole airplane)..... Use them or not?
Thanks!
Ken
Thanks!
Ken
having 2 young boys gives me a endless supply of cups to use for various uses mixing epoxy,paint,I even use them for sorting screws there handy.
so yes there fine to use for mixing epoxy
ORIGINAL: pdm52956
Food containers work pretty well PROVIDED they aren't wax coated. Don't mix epoxy in anything waxed.
Now that rings a bell! Yes, it was the waxed containers that were the problem. I feel much better now
Thanks!!
Ken
FL
I use the 4oz disposable plastic bathroom cups form Walmart. I also got a couple of the silicon baking cups that work very well and are easy to clean up too.
Scott Smith
Scott Smith
NC
I saw this tip in one of the RC mags this month. Communion Cups
http://www.ebay.com/itm/Communion-Cu...item45fcfcb996
1,000 mixing cups for only $22 bucks shipped!
My Feedback: (8)
Ken,
All you really have to be sure of is that the container has no wax. In my production I use 2 oz Dixi solo bathroom cups. They are cheap and unwaxed and available almost anywhere. Rarely will you mix up more that 2 Oz of epoxy unless you are doing a large layup. Fiberglass layup has a learning curve... just take your time and read all the instructions multiple times. The mistakes are REALLY troublesome and time consuming.
Dan
Dan Hines
Carolina Custom Aircraft
Dan
Dan Hines
If you have a lot of work to do with low viscosity epoxy, pour it onto a plastic picnic plate to delay hardening while you work.
If you are mixing small batches of thicker epoxy for building / repairs, just use Model Aviation magazine for that.
I'm getting ready to glass my rebuilt H9 CAP 232. Just finished the rebuild tonight so in the next few days, after getting all the dents etc. filled will commence on that project. Thanks for all the advice.
Stay away from Waxed cups always. Plastic (solo) and foam cups only work for epoxy resins, both will fail when using Poly or Vinyl esters. Some food containers will survive the esters too. I use plasticized paper cups they are reasonably priced, someone mentioned Aircraft Spruce which I have used in the past but I have a local source too.
ORIGINAL: AmishWarlord
I use the plastic lids from margarine containers or other containers that come with plastic lids...You can flex the lids to clean and reuse them after the epoxy sets too. The containers also come in handy ... I find the lids work well because they come in a few different sizes and they have that lip around the outside that contains the epoxy and also gives you a edge to scrape your brush or stickagainst if you need to .. My buddy always uses the old Sears catalogue , a page at a time..That works great too. Maybe even better in some ways. There is never any cleanup..Unless you clean your brush like I do...
