Composites Fabrication And Repair Carbon Fiber, Kevlar, Fiberglass and all the newest high tech composites
Substitute to 1-8 balsa planking
Reply
Old 03-31-2012, 06:28 PM
spike223
My Feedback: (27)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Substitute to 1-8 balsa planking
I was wondering if anyone have a suggestion for a composite substitute to 1-8 balsa planking on a fuselage.
spike223 is offline
Old 04-01-2012, 11:57 AM
brad59
My Feedback: (32)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Substitute to 1-8 balsa planking
Since nobody else jumped in......
I have been searching for easier and more efficient skinning products for some time. I had been aware of Fiberglass G-10 FR4 sheets available in either 3x4 or 4x4 panels for awhile but the cost made me shy away. But recently , after extensive searching, I found sources for the sheet at about half price from retail. I bought 11 4x4' sheets for around $325 as I recall, in various thicknesses.
I am getting ready to build a Ziroli Skyraider with foam core wings and stab that I have adjusted to be thicker as compensation for the very thin fiberglass. I will be using .010" skins and will also add a few spars but nothing too serious as the foam will keep the skin quite rigid, same as full scale stressed skin construction. The 1/6 Skyraider would have exactly 6 times (.063" aluminum) the thickness for the skins or thinner.
I have a friend who is doing his Skyraider wings and control surfaces with the G-10 over built up structure. He has a build thread on RC Scale builder, in the Ziroli section, under "Medal of honor Skyraider". You can see how he applies his skins. I also plan to do a build thread there to show the foam wing sheeting. I hate building wings so I plan to do as many of my future projects this way in the future.
I hope this will help you,
Brad
brad59 is offline
Old 04-01-2012, 02:41 PM
spike223
My Feedback: (27)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Brad
Thank you kindly!!!!
Exactely what I'm looking for!
spike223 is offline
Old 04-23-2012, 09:38 AM
fw190
My Feedback: (36)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I thought the reason for planking is for compound curves and then sanding the balsa smooths the shape. I dont see how glass fiber sheets can be used four compound curves.
fw190 is offline
Contact Us Archive Advertising Cookie Policy
