Repair of Top Flite Wire Wheel
MA
Hi all !
Does anyone have any idea on how to re-attach the rubber tire back onto the wire rim for a Top Flite Wire Wheel ?
I ran out of fuel and made a quick landing without any damage except the brunt of the force was taken on the two front tires/landing gear (taildragger) On one side of the landing gear, the rubber tire came off the rim.
The rim runs true and I do not want to force anything and bend/damage the wire rim. I bet someone out there has a tip/trick to get this done !
Here are two links to view the Top Flite Wire Wheel:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXCLX7&P=ML
www.top-flite.com/accys/topq6000.html
Thanks so much in advance.
Don
Don
RE: Repair of Top Flite Wire Wheel
make a wood peg the size or a little bigger than rim 1/16" warm tire in water place on peg slide up peg place on top of rim slide tire on to rim I hope this explains it well enough you can go to BVM web site they sell what i'am talking about
MA
Hi k12rc,
Thank you so much for your quick response. It is greatly appreciated.
I somewhat understand the concept, but when you mention a "peg" and when I look at the BVM "Tire Changing Tools" as seen here:
and here:
and see the "cone" tool, I am not sure how to make a peg that would replicate the cone (if needed), but I can certainly make the "pusher tool" as shown on the BVM site.
Again, I thank you for your quick response and help. Please excuse my ignorance on this matter... first time I have ever had to do this in 30 years! []
Don
