Composites Fabrication And Repair Carbon Fiber, Kevlar, Fiberglass and all the newest high tech composites
Fiberglassing a Kyosho 50size Cub ARF
Reply
Old 09-10-2012, 04:24 AM
Kostas1
Kostas1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Fiberglassing a Kyosho 50size Cub ARF
Guys,
I recently bought for a desent price a Piper Cub which needed some work.
I decided to strip off the covering, cover the exposed areas on the wing and fuselage with 1.5mm balsa sheets and fiberglass it, so as to finally, paint it!
Here are the first steps.
ID:	1799748   Click image for larger version
ID:	1799749   Click image for larger version
ID:	1799750   Click image for larger version
ID:	1799751   Click image for larger version
ID:	1799752   Click image for larger version
ID:	1799753   Click image for larger version
ID:	1799754   Click image for larger version
Kostas1 is offline
Old 09-11-2012, 12:04 AM
Kostas1
Kostas1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Fiberglassing a Kyosho 50size Cub ARF
Here's the first side almost totally covered with balsa.
Kostas1 is offline
Old 09-12-2012, 05:27 AM
Kostas1
Kostas1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Some progress on the balsa sheeting.
ID:	1800419   Click image for larger version
Kostas1 is offline
Old 09-12-2012, 06:01 AM
Kostas1
Kostas1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
And here is what I use as a putty to cover small holes or other areas on the balsa.
As you see I used a tiny amount of water to thin the putty so as to penetrate into the difficult areas more easily.
ID:	1800436   Click image for larger version
Kostas1 is offline
Old 09-12-2012, 06:06 AM
Kostas1
Kostas1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here's the putty after using some drops of water, while mixing it with the spatula.
ID:	1800438   Click image for larger version
ID:	1800439   Click image for larger version
Kostas1 is offline
Contact Us Archive Advertising Cookie Policy
