PVA release, Elmer's White Glue pva?
IL
Elmers is not poly vinyl alcohol! Take it from one who has had the experience, just wax may be okay for some but all you need is for a layup to get stuck in a mold just once and both get destroyed to rely on both wax and PVA. Regards.
Yeah 5 coats of wax and 1 of PVA. Works a treat.
If you have a stuck mould just inject water between plug and finished article and it comes apart no probs.
PVA just dissolves on H20
Hi gjs,
I belive that the PVA in white glue stands for poly vinyl acetate not poly vinyl alcohol. Same letters, but big difference.
Hope this helps,
Kev
Hope this helps,
Kev
RE: PVA release, Elmer's White Glue pva?
In a pinch, you can use a spray can of hail spray, I have used Aqua Net (sp?) along with lots of waxing, waxing first obviously.
Bob
Bob
GJS,
If you are looking at a substitute because you cant find some.....
Any marine supply or boat repair shop should carry it.
The stuff leaves a micro thin saran-wrap-like purple film that rolls off.
IL
You could probably use axel grease, I suppose, but I think that I would still go with PVA. It is tried to tested and works fine. Regards.
