Composites Fabrication And Repair Carbon Fiber, Kevlar, Fiberglass and all the newest high tech composites
Big Cowling
Reply
Old 03-22-2013, 03:29 AM
sensei
sensei's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Big Cowling
They say a picture is worth a thousand words, so for those interested; here is a short pictorial of building a simple engine cowling plug, lay up block, and cowling from beginning to end.
Bob
ID:	1865073   Click image for larger version
ID:	1865074   Click image for larger version
ID:	1865075   Click image for larger version
ID:	1865076   Click image for larger version
ID:	1865077   Click image for larger version
ID:	1865078   Click image for larger version
ID:	1865079   Click image for larger version
ID:	1865081   Click image for larger version
ID:	1865082   Click image for larger version
ID:	1865083   Click image for larger version
sensei is offline
Old 03-22-2013, 03:32 AM
sensei
sensei's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Big Cowling
Continued.
ID:	1865085   Click image for larger version
ID:	1865086   Click image for larger version
ID:	1865087   Click image for larger version
ID:	1865088   Click image for larger version
ID:	1865089   Click image for larger version
ID:	1865090   Click image for larger version
ID:	1865091   Click image for larger version
ID:	1865093   Click image for larger version
ID:	1865094   Click image for larger version
ID:	1865095   Click image for larger version
sensei is offline
Old 03-22-2013, 03:34 AM
sensei
sensei's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Continued.
ID:	1865097   Click image for larger version
ID:	1865098   Click image for larger version
ID:	1865099   Click image for larger version
ID:	1865100   Click image for larger version
ID:	1865101   Click image for larger version
ID:	1865102   Click image for larger version
ID:	1865103   Click image for larger version
ID:	1865105   Click image for larger version
ID:	1865106   Click image for larger version
ID:	1865107   Click image for larger version
sensei is offline
Old 03-22-2013, 03:40 AM
sensei
sensei's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
End.
Bob
ID:	1865109   Click image for larger version
ID:	1865110   Click image for larger version
ID:	1865111   Click image for larger version
ID:	1865112   Click image for larger version
ID:	1865113   Click image for larger version
ID:	1865114   Click image for larger version
ID:	1865115   Click image for larger version
sensei is offline
Old 03-22-2013, 06:45 AM
GarySS
My Feedback: (13)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice story in pictures. What kind of foam block did you use and where purchased? What glue did you use to adhere the blocks together? I've got a future project in mind that will use foam for body shaping, hence the questions. Thankx
GarySS is offline
Old 03-22-2013, 09:49 AM
sensei
sensei's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: GarySS
That is just your run of the mill 1-1.5 lb. density styrofoam, I get mine from a place here in San Antonio, but I am sure if you google you can get it someplace near you. I glue everything together with either Gorilla glue and/or hot glue sticks from Lowe's or Home Depot then I start shaping with my wire brush and sand paper.
Bob
sensei is offline
Old 03-24-2013, 04:54 PM
ARUP
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice post! You used epoxy resins. If you wanted to use polyester then the foam would need to be sealed.
ARUP is offline
Old 03-24-2013, 05:16 PM
sensei
sensei's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Your right, I always use epoxy resin, it is just easier to glass directly to styrofoam.
Bob
sensei is offline
Old 03-26-2013, 06:52 PM
Leroy Gardner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice work Bob but you leave much out when you do a illustration like that. I suppose others can figure out the left out details like the desolved foam method or the hack and whack or maybe it just slid off. Nice job just the same. Looks like you could use some cup gaskets, you wouldn't have to tie a rag around your gun.
Leroy
Leroy Gardner is offline
Old 03-27-2013, 02:38 AM
sensei
sensei's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Leroy Gardner
Leroy
Thanks Leroy,
I figure if someone wants to know more, all they need to do is ask and I will be happy to explain.
Bob
sensei is offline
Old 03-28-2013, 04:41 PM
DennisD
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have some questions Bob, if you don't mind.
In pictures 9 & 10 in post 3, it looks like you are using some fan fold foam as a filler when you are laying up the cowl. Can you explain what that is all about?
And also, what the heck is picture 11 in post 3 supposed to be showing? Is that some lost foam there? It looks like a suction hose there. What's going on?
Regards,
Dennis
DennisD is offline
Old 03-28-2013, 05:56 PM
sensei
sensei's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Picture 9 is me laying up 4 oz. cloth, .125" thick PVC core and the use of E-Z Poxy 10 laminating resin. Picture 10 is me laying up the solid ply areas with 6 oz. cloth doublers. Picture 11 is the consolidation of the layup using a perforated release media, a 4.5 oz. breather, and the use of a vacuum bag, the hose you see is the vacuum source to the bag. The reason I used the PVC core is simple, it allowed me to produce a cowling this large with a finished weight of under 2 lbs. by using less glass and resin. Now in comparison to a 50% Bill Hemple Extra 260 cowl I personally weighed of a stocky 5+ lbs. this 55% Extra 260 cowling is very light for it's size.
Bob
sensei is offline
Old 04-03-2013, 10:28 AM
dbsonic
dbsonic's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wow great work! What light brown body filler is that you are using?
dbsonic is offline
Old 04-13-2013, 06:11 PM
sensei
sensei's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: dbsonic
Thanks for the kid words, the filler is just some run of the mill bondo from the local automotive store.
Bob
sensei is offline
Old 09-23-2013, 09:08 AM
stevenmax50
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello. I have decided to try my hand at making a glass cowl. Your pics are excellent, but I do have a question. How do you remove the foam core?
stevenmax50 is offline
Old 09-23-2013, 10:40 AM
sensei
sensei's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It comes out as part of the master model, or you can poor a little acetone on it and within minutes it melts to a very sticky liquid that you poor out.
Bob
sensei is offline
Old 09-23-2013, 11:23 AM
foodstick
foodstick's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I really love threads like this, there is nothing in the hobby more satisfying than the craftsmanship of modelers...
foodstick is offline
Old 09-23-2013, 12:20 PM
sensei
sensei's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks foodstick.
Bob
sensei is offline
Old 09-23-2013, 08:30 PM
soarrich
My Feedback: (98)
soarrich's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you coat the foam with packing tape, then glass it the foam comes out much more cleanly.
soarrich is offline
Old 09-24-2013, 03:19 AM
sensei
sensei's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you did not notice, the foam was shaped and glassed with epoxy resin on purpose, this gave me a stable master model that I tooled from. The master model was then demolded clean, and in one piece. The use of packing tape on shaped foam is fine for those that wish to skip the tooling process and fly the molded splash off the foam but those are usually heavier due too the comedic aspect prior to paint and not something I would personally consider on any one of my airplanes but that is just me. Now I have used mylar tape on foam and cardboard plugs in the construction of things like fuel tanks, but then again I am not trying to create a smooth paintable surface. The picture below illustrates the packing tape process I used on this tank some 14 years ago.
Bob
sensei is offline
Contact Us Archive Advertising Cookie Policy
