Composites Fabrication And Repair Carbon Fiber, Kevlar, Fiberglass and all the newest high tech composites
cowl repair
Reply
Old 07-22-2013, 12:25 PM
rt3232
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default cowl repair
To any one
To start I have an old mold for a cowl for a dragon lady so I layed up a new cowl using polyester risen, and got a nice cowl out of the mold.
my problem is I need to extend it about 3/4 to fit new engine install, So I layed up a 2 inch setion of the atf part of the cowl mold, and again got a nice piece out of the mold, I have now trimmed a 1/2 inch from the cowl and thimmed the add on pice to fit the aft edge of the cowl, with enough lenght to do a final trim when I install it to the bird.
The question is what would be the best way get a ( temp attachment) so I can sand out side of the cowl seam and add 2 layers of 1oz cloth, when that is cured will sand out a strip in side to add reinforcement.
Would thick CA work ? or somethine else, I don't want to use somthing that will prevent an good bond when I add the renforcement
Thanks for any suggestions
Cheers Bob T
rt3232 is offline
Old 07-23-2013, 03:52 AM
rt3232
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: cowl repair
Ok seeing no one wanted to offer a suggestion I went wit 5 min epoxy I did bevel the edges a bit and will tals a bit if fill and sanding, but for this old bir it will do
Catxh you all later
Cheers Bob T
rt3232 is offline
Contact Us Archive Advertising Cookie Policy
