Composites Fabrication And Repair Carbon Fiber, Kevlar, Fiberglass and all the newest high tech composites
Fiberglassing Between Two (2) Panes of Glass
Reply
Old 09-01-2013, 09:36 AM
redtail
My Feedback: (15)
redtail's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Fiberglassing Between Two (2) Panes of Glass
Please help. I am glassing one of two plywood roof top panels for the 25% O-1 Bird Dog and I want to put it between two panels of glass. The glass panels would then have weights placed on top until the epoxy cured to ensure a straight, flat panel to be installed on the roof. Should I use a release agent (car wax) of some kind on both inside panels of the glass? I'm not going to tell you why I asked that question (smile). Also, about how long should I let the composite of wood/glass stay between the glass panels under the weights? Many thanks. Chic
redtail is offline
Old 09-01-2013, 10:43 AM
speedracerntrixie
My Feedback: (29)
speedracerntrixie's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Get some 2 mil Mylar, wax it and do your panel between two sheets of the waxed Mylar. Then put between the two sheets of glass. How long depends on the epoxy system you are using and the temp where it is curing.
speedracerntrixie is offline
Old 09-01-2013, 11:17 AM
redtail
My Feedback: (15)
redtail's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Many thanks, one last question, once dry, how do I remove the wax that accumulated on the now glassed plywood prior to my sanding, priming, and painting it? Again thanks for the help and advice. Chic
redtail is offline
Old 09-01-2013, 11:59 AM
speedracerntrixie
My Feedback: (29)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You buff the wax off the mylar. There won't be much transfer to the laminate. Wipe with acetone, sand, wipe again and prime.
Old 09-01-2013, 12:13 PM
redtail
My Feedback: (15)
redtail's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Your a "Good Man". God, I can't thank you enough. Off to the shop. Chic
redtail is offline
Old 09-02-2013, 05:51 AM
redtail
My Feedback: (15)
redtail's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Speedracerntrixie, your procedure worked perfectly, can't thank you enough. Perfect. Chic
redtail is offline
Contact Us Archive Advertising Cookie Policy
