Go Back  RCU Forums > RC Airplanes > Composites Fabrication And Repair
Reload this Page >
Fabric Covering over composite ?? Can it be done?
Composites Fabrication And Repair Carbon Fiber, Kevlar, Fiberglass and all the newest high tech composites
Old 11-17-2013, 05:14 AM
zzw26n
My Feedback: (45)
zzw26n's Avatar
Default Fabric Covering over composite ?? Can it be done?
I'm working on a fantasy racer Gee Bee R3 and during this era of Aircraft, it's looks to me that many aircraft had a combination of fabric covering and aluminum skin, is this correct?
The question I had: has anyone ever put fabric covering over a composite surface? with good results? and may I ask what did you use?
I want to cover certain areas in fabric (circled red area) and then the other area's with shiny aluminum. (3M Chrome vinyl)
First picture shows area to be covered.
Second picture shows desired results.
ID:	1939935   Click image for larger version
Old 11-17-2013, 07:54 AM
Jaketab
Subscribed.
Old 11-17-2013, 01:52 PM
sensei
sensei's Avatar
The cloth will stick just fine to the composite surface providing you abrade the entire area to a water break free surface prior to application, I have done this in the past on a few composite structures with open bay areas and have never had any issues with the system I used. (Stits full scale covering system). Just a note, most full scale guys I know, try to get a show type automotive finish on their birds, even the cloth covered ones they try to get rid of the cloth look altogether, and just about all RC guys try to get a full scale finish with the cloth look. I hope it all works out for you because this a a very cool project for sure.
Bob
Old 11-17-2013, 02:22 PM
zzw26n
My Feedback: (45)
zzw26n's Avatar
Bob, point taken. The Howard DGA-4 and DGA-5 have both cloth and aluminum construction, and to your point, the cloth is as glossy as the aluminum.
Weight is a big factor in the build, so I'm starting to shy away from the cloth. Really appreciate your input, it's valued very much.
Old 11-18-2013, 04:49 PM
sensei
sensei's Avatar
This really is an awesome project and I am surprised that nobody else has chimed in about it...
Bob
Old 11-18-2013, 09:58 PM
saramos
saramos's Avatar
I would consider testing Flight Metal to see if you can get a good polish on it. it will be a more appropriate color than chrome.
Scott
Old 11-19-2013, 03:36 AM
zzw26n
My Feedback: (45)
zzw26n's Avatar
Scott
Scott,
I've seen Models on display at the Toledo Show, very impressive finish. I've never worked with it, but was told it's heavier then most all finishes?
Old 11-19-2013, 04:54 AM
saramos
saramos's Avatar
Based on the data on their website, it comes out to just under 3 oz. per square yard.
Scott
