Composites Fabrication And Repair Carbon Fiber, Kevlar, Fiberglass and all the newest high tech composites
Cutting .060" Carbon Fiber Sheet
Reply
Old 12-15-2013, 05:46 PM
SrTelemaster150
SrTelemaster150's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Cutting .060" Carbon Fiber Sheet
I need to cut some strips to laminate an engine beam mount. I need to cut several 2 3/8" wide strips. I was thinking of using an Exacto knife & metal straight edge to score both side & braek over an edge.
Any suggestions?
I'll be lamiating the strips W/1/16" birch ply & doing the finish cuts W/a scroll saw.
SrTelemaster150 is offline
Old 12-16-2013, 04:40 AM
sensei
sensei's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you are cutting unidirectional the scoring will work ok, for you, just clean up the edges with a sanding block. Now if you are cutting bidirectional, use a cutoff wheel on a die grinder or set up a fence on a table saw with a carbide blade and a close fit blade slot.
Bob
sensei is offline
Old 12-16-2013, 07:39 AM
SCALECRAFT
SCALECRAFT's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
And use a respirator.
Steve
SCALECRAFT is offline
Reply
Display Modes
