Composites Fabrication And Repair Carbon Fiber, Kevlar, Fiberglass and all the newest high tech composites
Kevlar Live Hinges?
Reply
Old 01-15-2018, 10:35 AM
Vettster
Vettster's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Kevlar Live Hinges?
Hi Guys! Need a grey area cleared up for me. Ive searched many of the other threads but can't seem to find the info I need. Im building a 7 foot long jet and I am going to be using live hinges. What I would like to know for sure! is what weight kevlar is used... I've read 2 oz(very hard to find) and others using 5.8oz which seems heavy to me. Also would like to know a layup schedule for it. ie.. Is the kevlar covered with a layer of 2-4oz?
Any help is appreciated. Here's a link to what I'm working on
https://www.rcgroups.com/forums/show...powered-WETJET
Vettster is offline
Old 01-24-2018, 08:43 AM
Lownverted
Lownverted's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey,
Plenty of lightweight Kevlar options here: Aramid (Kevlar ) Fabric | Page 1 of 1
I use 1.7 laid on a bias, and sandwich it between layers of glass. If its too stiff for your liking, you can "sand" down through the hinge line glass, but obviously not through the Kevlar. I use a cut off wheel by hand and a straight edge.
Good luck
Red
Lownverted is offline
Old 01-24-2018, 01:03 PM
Vettster
Vettster's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the info and link Red.
Vettster is offline
Old 01-26-2018, 03:44 PM
dbsonic
dbsonic's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I used a triangle file but its a lot of work however gives good control to get clear outer layup right up to the kevlar.
But most lives hinges are not kevlar these days... they are polyester peel-n-ply. But same thing needs to be done to clear the outer layup. For most ARFs it looks like it is done with a mill of some kind set to a certain depth.
dbsonic is offline
Old 01-26-2018, 03:51 PM
Vettster
Vettster's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Peel ply!..very good to know.. thanks for the tips.
Vettster is offline
Old 01-26-2018, 03:59 PM
GREG DOE
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Peel ply. Polyester dress liner material.
GREG DOE is offline
Old 01-26-2018, 04:04 PM
dbsonic
dbsonic's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Now here is the really interesting part, it is simply dress liner that you can get at any fabric store. no joke.(post script, greg beat me to it!).
dbsonic is offline
Old 01-26-2018, 04:26 PM
Vettster
Vettster's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yup...I got plenty of both. The better would be the dress stuff since the peel ply has a coating to make it easier to remove(not stick aswell)
Vettster is offline
Old 01-26-2018, 05:27 PM
dbsonic
dbsonic's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Interesting. The kind used in a CARF plane has a red stripe pattern to it. I think it is Diatex brand from Europe. I agree you want it to stick to some degree.
dbsonic is offline
Old 01-26-2018, 05:34 PM
Vettster
Vettster's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That's even more interesting because the Red stripe is used to let you know that the PP is coated. But then again.. it just might be a companies thing.
The coated stuff I use has the Red stripes on it.
Vettster is offline
Old 01-26-2018, 05:37 PM
Vettster
Vettster's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
But even though its coated.. you need to pull very hard to get it off.. and dont forget its on top when peeled off. Now if it were sandwiched between two layers of glass? well I think it would be very difficult to remove, coated or not.
Vettster is offline
Old 01-26-2018, 06:31 PM
dbsonic
dbsonic's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
First time I tried these live hinges I bagged up a sample to see how it would play out. You could do the same will various approaches/material.
dbsonic is offline
Old 02-13-2018, 01:06 PM
CRye
My Feedback: (15)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Watch out for:
"Strongly hygroscopic Kevlar fibre is considered to provide an easy route for moisture ingress and led to the observed inhomogeneity in the plasticisation of specimens." ie moisture will lower the mechanical properties of kevlar and wick moisture into the structure.
That may be why the pros use Dacron. But, Dacron is also highly susceptible to UV damage. That,s why in cloth covered full scale after an adhesion and shrinking layer of paint is applied the next layer(s) are called silver. It is actually aluminum powder dissolved in butyrate dope to create a light barrier even cotton is subject to light damage or at least the glue used. Even that has its own problems as the layer with Al is where defoliation of paint begins. Al powder is almost a lubricant. IN full scale we are warned that it only takes f few hours for discernable UV damage to begin.
Some of the live hinge detachments we all hear about may have begun with UV damage since we often park our planes in the sun. If I ever build my own live hinge structure I was going to take a look at Stits high UV block high flex non Al light block layer.
Bla Bla Bla, but I also have many questions but will look and then post.
Charles
CRye is offline
Old 02-13-2018, 10:08 PM
GREG DOE
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
CRye You used the word "defoliation". Isn't that what Agent Orange was used for? I'm wondering if you should have used "d-lamination" instead?
GREG DOE is offline
Old 02-17-2018, 02:05 PM
Vettster
Vettster's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by CRye View Post
Watch out for:
Charles
Charles.. sorry for the late reply.. working long hours. Thanks very much for taking the time to post what is very interesting info. I think I will be going with kevlar. Water will most likely not be an issue as the Live hinges are only used in the Elevators and they will be about 18" above the water line.
Trevor
Vettster is offline
Old 02-17-2018, 02:38 PM
GREG DOE
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Vettsted, Be warned Kevlar is tough to cut, but be sure to let us know how it works out.
GREG DOE is offline
Old 02-17-2018, 03:41 PM
Vettster
Vettster's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Greg..but I've found it very easy to cut with the right scissors. You need sarrated scissors.
cheers
Vettster is offline
Old 02-17-2018, 04:55 PM
GREG DOE
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Vettster, Those "serrated scissors" are called "pinking shears". Their purpose is help keep fabric from unraveling. 70 years ago I watched my mother using her pinking shears, and she was very protective of them. I think my wife inherited them, and they are somewhere here in the house? They now make "rotary pinking shears". I use a rotary cutter for cutting glass cloth, but I've never used a rotary pinking cutter. Anyway, good luck.
GREG DOE is offline
Old 03-19-2018, 04:09 PM
Vettster
Vettster's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hinge turned out great. I used the peel ply.
Vettster is offline
