Composites Fabrication And Repair Carbon Fiber, Kevlar, Fiberglass and all the newest high tech composites
Painting master plugs
Reply
Old 02-08-2018, 12:42 AM
Typhoon Phil
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Painting master plugs
I am finishing off a set of aeroplane plugs and have quite a good finish using high build primer (Wet sanded down with 200/400/600 grade paper) after adding panel lines and surface detail it will be rubbed back with 800 & 1200 grade paper... question is do i then need to use a paint (if so what do you guys recommend) to get a final surface ready to make moulds from it or can i just leave the very smooth and polished primer surface.
Typhoon Phil is offline
Old 02-17-2018, 03:57 PM
Vettster
Vettster's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Phil.. hope this is not to late. But I just sand the primer with 400/600/800 wet paper. Then 10 coats of parting wax(the good stuff from the composites store.)
Vettster is offline
Old 02-24-2018, 04:41 PM
acdii
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I hit mine with a clear coat from a spray can, wet sand with 1500 grit, then a couple coats of parting wax and then 3 coats of PVA.
acdii is offline
Old 02-25-2018, 10:53 AM
alex5
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I agree,too much paint is something more to go wrong like incompatibility,or incomplete drying.Keep it simple,try one without more paint...then work up.
alex5 is offline
Old 02-25-2018, 05:02 PM
acdii
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Keep in mind that primer, except for sealing primer, is porous, and may give negative results no matter how much wax and PVA is used. You should use some kind of top coat that seals the primer. The more glossy the surface, the better the mold will be in the end.
acdii is offline
